Help! Airplay only playing audio!
Discussion in 'AirPlay' started by weberjo, Oct 17, 2012.
  1. weberjo
    weberjo
    Oct 17, 2012
    Hi, hoping someone can help. Trying to play a movie from iPad air played to Apple TV, has always worked previously but not only plays sound while the video continues to play on the iPad itself.
    Apple TV has recently been updated, as has the iPad.
    Thanks!
  2. apple911.ca
    apple911.ca
    Oct 17, 2012
    Try to reset all settings, if that does not work you could try a restore and setup as new. You can follow the steps on my website if needed (see username)
  3. JayMcBee
    JayMcBee
    Nov 9, 2013
    Some apps just stream audio - is it the same app just streaming audio now that had video before?
    Did you try resetting your Apple TV to factory settings?
    (I suppose you already tried rebooting the Apple TV, iPad and router)
    Cheers,
    Jan
  4. Webalistic
    Webalistic
    Jul 26, 2010
    56
    I read somewhere that in IOS7 some quality checking is done. If the connection doesn't meet the minimum requirements, the airplay option 'reduces' to Audio only.
    I used to be able to airplay to my Raspberry Pi with XBMC. Since IOS7 it only shows the Pi as an audio streaming option. Bit of a shame really. Never experienced 'quality issues' before.
airplay audio only
airplay is only playing sound
airplay only playing audio
airplay only playing sound
airplay only plays audio
airplay only plays audio not video
airplay only plays sound
airplay playing audio only
airplay sound only
apple airplay only playing audio
