Hello Everyone! First Post, and already a problem
Sean71596
Michigan
Hello,
M'name's Sean, and I am an avid PC gamer, who also uses an iPad 1. Yeah that's about it. Can be found on steam under the name {BBG} Sean71596.
Anyway-Today, I upgraded from 4.3.5 (jailbroken by friend who I bought it from a year ago, said he used greepois0n) to 5.0.1. I Jailbroke it today with Redsn0w, using the ISPW from 5.0. All went fine, and I used basic apps and stuff. That is, until I installed and proceeded to run AptBackup (yes I had backed it up before upgrade). It went for about 15 minutes, at which point it rebooted. Keep in mind, this is a tethered jailbreak, and I am not sure if things can go wrong if you reboot it without redsn0w. Anywho, when it boots up, it acts like an iPod touch in one corner, asking for a password in one corner of the screen, with an iPod touch-esqe keyboard. You can type maybe 2 letters, and it resprings, an iPad keyboard comes up, and you can then unlock it. When I unlocked it, it gave me this message:
We apologize for the
inconvenience, but SpringBoard
has just crashed
MobileSubstrate /did not/ cause
this problem: it has protected you
from it
Your Device is now running in
Safe Mode. All extentions that
support this safety system are
disabled
Reboot (or restart SpringBoard) to
return to the normal mode. To
return to this dialog touch the
status bar
Tap Help to for more help
If you respring, it works for about 2 seconds, then crashes and gos into safe again. Tried rebooting tethered, no luck. I will try to uninstall more extentions, but if that doesnt work,
I have no idea what to do
-Sean
S
Sean71596
Michigan
Update- I went through uninstalling cydia apps I thought looked suspicious (yes I made a list of them so I can reinstall later). Then I saw that you could use CrashReporter. So I installed it, resprang, with it crashing, and looked at the report. I repeated the process a few times. It says there is no Primary or Secondary Suspect, but the only suspect, the Tertiary suspect was MailDataProvider, every time. So I looked through cydia for "MailDataProvider" and Mail Data Provider. No luck. I tried un-associating my email from Mail, contacts, and all that other good stuff. I also tried doing everything with wifi off. no luck. What is this MailDataProvider, and how do I kill it so it wont do this?
BTW: I HAVE run the redsn0w's safe mode fix. It didn't fix
Mickey330
Western NY state (USA)
I did not quite follow - when you rebooted the iPad, did you reboot it, tethered, by (1) pressing the "Select IPSW" button (and selecting the iOS 5.0 firmware) and then (2) pressing the "Just Boot" button? It just seems, from your phrasing, that you didn't do this. Apologies if I'm confused...
Honestly, if you did do a tethered reboot, both after the initial jail break and every time thereafter, all I can think of is for you to do a do-over: re-install 5.0.1 and then re-jailbreak it. Sorry, but I got nothing else.
leelai
Brisbane, Australia
Hi and welcome to the Forum!
I'm just welcoming you, I have no clue on JB.
S
Sean71596
Michigan
Thanks for all the welcomes everyone. Anywho, I always boot it tethered (doens't seem to even boot if i dont). I believe it is a cydia app, for it happened when I reinstalled all my cydia apps from Aptbackup. If I do a restore, how should I rebackup by cydia apps?
Mickey330
Maybe it's the fact that you went from 4.x to 5.x. That is actually a very big leap and maybe AppBackup can't handle it in restoring your Cydia tweaks?
Here's my suggestion: Ensure you have a good backup of your stock App Store apps and stuff. Make a list of all your Cydia tweaks that you'll want back on the iPad (I know it's rather OCD, but I keep an Excel spreadsheet). Restore your iPad to a stock iOS 5.0.1 and put all the stock stuff back on. Once that's done, then run the jail break. After you're jail broke again, go to Cydia and manually download your tweaks and such. Yeah, it's [going to be] a royal pain, but it should work.
When I upgraded from 4.3.3 to 5.0.1, that's the process I did, with no troubles. Yeah, I had to reboot tethered a few times while downloading some of the Cydia tweaks - but that was only in the first load session. And, all the Cydia stuff is treated like the App Store - if you've paid for it, you don't have to pay for it again, just go get it.
Good luck and I hope this helps/works.
S
Sean71596
Michigan
That's what I was thinking. I'm Thinking that AptBackup might of forcibly restored some cydiapps that haven't been revamed for ios5 yet. Cydia wouldve stopped it if I tried that manually, but yeah.
Here is the Crash Log-
## Crash log
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>AutoSubmitted</key>
<true/>
<key>SysInfoCrashReporterKey</key>
<string>7f56ddb3dbd0a1ef8a14e1c06b188b5a885bcda7</string>
<key>bug_type</key>
<string>109</string>
<key>description</key>
<string>Incident Identifier: 71806806-B39F-4000-84E7-34074C2BB89B
CrashReporter Key: 7f56ddb3dbd0a1ef8a14e1c06b188b5a885bcda7
Hardware Model: iPad1,1
Process: SpringBoard [168]
Path: /System/Library/CoreServices/SpringBoard.app/SpringBoard
Identifier: SpringBoard
Version: ??? (???)
Code Type: ARM (Native)
Parent Process: launchd [1]
Date/Time: 2011-12-15 09:37:00.096 -0500
OS Version: iPhone OS 5.0.1 (9A405)
Report Version: 104
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x00000000, 0x00000000
Crashed Thread: 0
Last Exception Backtrace:
(0x33bb08bf 0x352cc1e5 0x33bb3acb 0x33bb2945 0x33b0d680 0x4f5410 0x581b5 0x34c1d961 0x34c1d3bf 0x34c1cd2d 0x35747df3 0x33b84553 0x33b844f5 0x33b83343 0x33b064dd 0x33b063a5 0x35746fcd 0x34c4b743 0x2ea33 0x2e074)
Thread 0 name: Dispatch queue: com.apple.main-thread
Thread 0 Crashed:
0 libsystem_kernel.dylib 0x3617d32c 0x3616c000 + 70444 // __pthread_kill + 0x8
1 libsystem_c.dylib 0x34a29f54 0x349dc000 + 319316 // pthread_kill + 0x30
2 libsystem_c.dylib 0x34a22fe4 0x349dc000 + 290788 // abort + 0x58
3 libc++abi.dylib 0x35ed4f64 0x35ece000 + 28516 // abort_message + 0x28
4 libc++abi.dylib 0x35ed2346 0x35ece000 + 17222 // __ZL17default_terminatev + 0x12
5 libobjc.A.dylib 0x352cc2dc 0x352c3000 + 37596 // _objc_terminate + 0x8c
6 libc++abi.dylib 0x35ed23be 0x35ece000 + 17342 // __ZL19safe_handler_callerPFvvE + 0x46
7 libc++abi.dylib 0x35ed244a 0x35ece000 + 17482 // std::terminate() + 0xe
8 libc++abi.dylib 0x35ed381e 0x35ece000 + 22558 // __cxa_rethrow + 0x52
9 libobjc.A.dylib 0x352cc22e 0x352c3000 + 37422 // objc_exception_rethrow + 0x6
10 CoreFoundation 0x33b0653e 0x33af7000 + 62782 // CFRunLoopRunSpecific + 0x18e
11 CoreFoundation 0x33b0639e 0x33af7000 + 62366 // CFRunLoopRunInMode + 0x62
12 GraphicsServices 0x35746fc6 0x35743000 + 16326 // GSEventRunModal + 0x96
13 UIKit 0x34c4b73c 0x34c1a000 + 202556 // UIApplicationMain + 0x43c
14 SpringBoard 0x0002ea2c 0x2b000 + 14892
15 SpringBoard 0x0002e06c 0x2b000 + 12396
Thread 1 name: Dispatch queue: com.apple.libdispatch-manager
Thread 1:
0 libsystem_kernel.dylib 0x3616d3b4 0x3616c000 + 5044 // kevent + 0x18
1 libdispatch.dylib 0x36e93e78 0x36e87000 + 52856 // _dispatch_mgr_invoke + 0x2c4
2 libdispatch.dylib 0x36e93b96 0x36e87000 + 52118 // _dispatch_mgr_thread + 0x1e
Thread 2:
0 libsystem_kernel.dylib 0x3617dcd4 0x3616c000 + 72916 // __workq_kernreturn + 0x8
1 libsystem_c.dylib 0x349e630a 0x349dc000 + 41738 // _pthread_wqthread + 0x262
2 libsystem_c.dylib 0x349e609c 0x349dc000 + 41116 // start_wqthread + 0x0
Thread 3 name: Dispatch queue: com.apple.root.default-priority
Thread 3:
0 libsystem_kernel.dylib 0x3617d068 0x3616c000 + 69736 // __psynch_cvwait + 0x18
1 libsystem_c.dylib 0x349ebf2e 0x349dc000 + 65326 // _pthread_cond_wait + 0x27a
2 libsystem_c.dylib 0x349ebcaa 0x349dc000 + 64682 // pthread_cond_wait + 0x22
3 Foundation 0x315eacca 0x315da000 + 68810 // -[NSCondition wait] + 0xbe
4 Foundation 0x315de40c 0x315da000 + 17420 // -[NSObject(NSThreadPerformAdditions) performSelector:eek:nThread:withObject:waitUntilDone:modes:] + 0x360
5 Foundation 0x31606fae 0x315da000 + 184238 // -[NSObject(NSThreadPerformAdditions) performSelector:eek:nThread:withObject:waitUntilDone:] + 0x66
6 MailDataProvider 0x0430fbca 0x430e000 + 7114 // -[_MFMailDataProviderThread registerNotificationObserver:forAccounts:shouldLaunchMobileMail:] + 0x16e
7 MailDataProvider 0x04312bd2 0x430e000 + 19410 // -[MFMailDataProvider dealloc] + 0x966
8 MailServices 0x30466362 0x30462000 + 17250 // -[MSAccounts _listAccountKeys:handler:] + 0xc6
9 libdispatch.dylib 0x36e87d4e 0x36e87000 + 3406 // _dispatch_call_block_and_release + 0x6
10 libdispatch.dylib 0x36e9379c 0x36e87000 + 51100 // _dispatch_worker_thread2 + 0x100
11 libsystem_c.dylib 0x349e61c8 0x349dc000 + 41416 // _pthread_wqthread + 0x120
12 libsystem_c.dylib 0x349e609c 0x349dc000 + 41116 // start_wqthread + 0x0
Thread 4 name: com.apple.CoreAnimation.render-server
Thread 4:
0 libsystem_kernel.dylib 0x3616d010 0x3616c000 + 4112 // mach_msg_trap + 0x14
1 libsystem_kernel.dylib 0x3616d206 0x3616c000 + 4614 // mach_msg + 0x32
2 QuartzCore 0x31bf25b4 0x31b6a000 + 558516 // CA::Render::Server::server_thread(void*) + 0xec
3 QuartzCore 0x31c41e66 0x31b6a000 + 884326 // thread_fun + 0xa
4 libsystem_c.dylib 0x349ebc16 0x349dc000 + 64534 // _pthread_start + 0x13a
5 libsystem_c.dylib 0x349ebad0 0x349dc000 + 64208 // thread_start + 0x0
Thread 5 name: com.apple.CoreAnimation.IOMFB.AppleRGBOUT
Thread 5:
2 CoreFoundation 0x33b8441c 0x33af7000 + 578588 // __CFRunLoopServiceMachPort + 0x78
3 CoreFoundation 0x33b83154 0x33af7000 + 573780 // __CFRunLoopRun + 0x36c
4 CoreFoundation 0x33b064d6 0x33af7000 + 62678 // CFRunLoopRunSpecific + 0x126
5 CoreFoundation 0x33b83474 0x33af7000 + 574580 // CFRunLoopRun + 0x5c
6 QuartzCore 0x31c1d56c 0x31b6a000 + 734572 // CA::WindowServer::IOMFBServer::thread_body(void*) + 0x100
7 QuartzCore 0x31c41e66 0x31b6a000 + 884326 // thread_fun + 0xa
8 libsystem_c.dylib 0x349ebc16 0x349dc000 + 64534 // _pthread_start + 0x13a
9 libsystem_c.dylib 0x349ebad0 0x349dc000 + 64208 // thread_start + 0x0
Thread 6:
5 CoreFoundation 0x33b0639e 0x33af7000 + 62366 // CFRunLoopRunInMode + 0x62
6 Foundation 0x315deb7e 0x315da000 + 19326 // -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 0xfa
7 Foundation 0x315f852c 0x315da000 + 124204 // -[NSRunLoop(NSRunLoop) run] + 0x48
8 UIKit 0x34f273c0 0x34c1a000 + 3199936 // -[UIStatusBarServerThread main] + 0x2a0
9 Foundation 0x3167e59a 0x315da000 + 673178 // __NSThread__main__ + 0x412
10 libsystem_c.dylib 0x349ebc16 0x349dc000 + 64534 // _pthread_start + 0x13a
11 libsystem_c.dylib 0x349ebad0 0x349dc000 + 64208 // thread_start + 0x0
Thread 7 name: WebThread
Thread 7:
6 WebCore 0x33fc2128 0x33f1a000 + 688424 // __ZL12RunWebThreadPv + 0x18c
7 libsystem_c.dylib 0x349ebc16 0x349dc000 + 64534 // _pthread_start + 0x13a
8 libsystem_c.dylib 0x349ebad0 0x349dc000 + 64208 // thread_start + 0x0
Thread 8 name: com.apple.CoreAnimation.IOMFB.AppleCLCD
Thread 8:
Thread 9:
2 libsystem_kernel.dylib 0x3616e3dc 0x3616c000 + 9180 // mach_msg_receive + 0x14
3 IOKit 0x35768f7e 0x3574f000 + 106366 // brightnessThread + 0xea
Thread 10:
6 IOKit 0x35766a10 0x3574f000 + 96784 // __IOHIDSessionStartOnThread + 0x140
Thread 11:
6 SpringBoard 0x0009e16e 0x2b000 + 471406 // -[SBDisplay dealloc] + 0xdac2
Thread 12 name: com.apple.springboard.icongeneration
Thread 12:
6 SpringBoard 0x0009e028 0x2b000 + 471080 // -[SBDisplay dealloc] + 0xd97c
Thread 13 name: com.apple.coremedia.player.async
Thread 13:
3 CoreMedia 0x351f4000 0x351f1000 + 12288 // FigSemaphoreWaitRelative + 0xd4
4 MediaToolbox 0x32371fba 0x3236e000 + 16314 // fpa_AsyncMovieControlThread + 0x12
5 CoreMedia 0x35213bc6 0x351f1000 + 142278 // figThreadMain + 0x92
6 libsystem_c.dylib 0x349ebc16 0x349dc000 + 64534 // _pthread_start + 0x13a
7 libsystem_c.dylib 0x349ebad0 0x349dc000 + 64208 // thread_start + 0x0
Thread 14 name: Dispatch queue: SBIconGenerationSerialQueue
Thread 14:
0 MobileIcons 0x375065da 0x37501000 + 21978 // LICreateImageFromCachedUncompressedData + 0x22
1 UIKit 0x34dd70de 0x34c1a000 + 1822942 // +[UIImage(UIApplicationIconPrivate) _iconForResourceProxy:variant:variantsScale:] + 0x2a
2 UIKit 0x34dd706e 0x34c1a000 + 1822830 // +[UIImage(UIApplicationIconPrivate) _applicationIconImageForBundleIdentifier:format:scale:] + 0x6a
3 SpringBoard 0x0004fb54 0x2b000 + 150356 // -[SBApplicationIcon dealloc] + 0xa4
4 libdispatch.dylib 0x36e87d4e 0x36e87000 + 3406 // _dispatch_call_block_and_release + 0x6
5 libdispatch.dylib 0x36e92ccc 0x36e87000 + 48332 // _dispatch_queue_drain + 0xec
6 libdispatch.dylib 0x36e92b66 0x36e87000 + 47974 // _dispatch_queue_invoke$VARIANT$up + 0x1e
7 libdispatch.dylib 0x36e9376c 0x36e87000 + 51052 // _dispatch_worker_thread2 + 0xd0
8 libsystem_c.dylib 0x349e61c8 0x349dc000 + 41416 // _pthread_wqthread + 0x120
9 libsystem_c.dylib 0x349e609c 0x349dc000 + 41116 // start_wqthread + 0x0
Thread 15:
Thread 16 name: com.apple.NSURLConnectionLoader
Thread 16:
6 Foundation 0x315eabc2 0x315da000 + 68546 // +[NSURLConnection(Loader) _resourceLoadLoop:] + 0x12e
7 Foundation 0x315eaa8a 0x315da000 + 68234 // -[NSThread main] + 0x42
8 Foundation 0x3167e59a 0x315da000 + 673178 // __NSThread__main__ + 0x412
9 libsystem_c.dylib 0x349ebc16 0x349dc000 + 64534 // _pthread_start + 0x13a
10 libsystem_c.dylib 0x349ebad0 0x349dc000 + 64208 // thread_start + 0x0
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21 name: WiFiManager callback thread
Thread 21:
8 Foundation 0x315eaa8a 0x315da000 + 68234 // -[NSThread main] + 0x42
Thread 22:
2 AppSupport 0x31f66722 0x31f54000 + 75554 // CPDMTwoWayMessageWithPortPassing + 0x96
3 AppSupport 0x31f652c0 0x31f54000 + 70336 // -[CPDistributedMessagingCenter _sendMessage:userInfoData:eek:olKey:eek:olData:makeServer:receiveReply:nonBlocking:error:] + 0x168
4 AppSupport 0x31f659a6 0x31f54000 + 72102 // -[CPDistributedMessagingCenter _sendMessage:userInfo:receiveReply:error:toTarget:selector:context:nonBlocking:] + 0x366
5 AppSupport 0x31f63cfc 0x31f54000 + 64764 // -[CPDistributedMessagingCenter _sendMessage:userInfo:receiveReply:error:toTarget:selector:context:] + 0x38
6 AppSupport 0x31f63bc6 0x31f54000 + 64454 // -[CPDistributedMessagingCenter sendMessageAndReceiveReplyName:userInfo:error:] + 0x2e
7 MailServices 0x30465506 0x30462000 + 13574 // -[MSMailDefaultService _callMailServicesMethod:arg:reply:error:responseSelector:] + 0x10a
8 MailServices 0x30466e72 0x30462000 + 20082 // -[MSNotificationService _addObserverClientForNotifications] + 0x86
9 MailServices 0x30466656 0x30462000 + 18006 // +[MSNotificationService registerNotificationObserver:forAccounts:shouldLaunchMobileMail:] + 0x86
10 MailDataProvider 0x0430fcce 0x430e000 + 7374 // -[_MFMailDataProviderThread _registerNotificationObserverInfo:] + 0xce
11 CoreFoundation 0x33bb380c 0x33af7000 + 772108 // __invoking___ + 0x3c
12 CoreFoundation 0x33b0e7da 0x33af7000 + 96218 // -[NSInvocation invoke] + 0x9a
13 CoreFoundation 0x33b0f224 0x33af7000 + 98852 // -[NSObject performSelector:withObject:] + 0x24
14 Foundation 0x3167e750 0x315da000 + 673616 // __NSThreadPerformPerform + 0x158
15 CoreFoundation 0x33b84afc 0x33af7000 + 580348 // __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 0x8
16 CoreFoundation 0x33b842c8 0x33af7000 + 578248 // __CFRunLoopDoSources0 + 0xd0
17 CoreFoundation 0x33b8306e 0x33af7000 + 573550 // __CFRunLoopRun + 0x286
18 CoreFoundation 0x33b064d6 0x33af7000 + 62678 // CFRunLoopRunSpecific + 0x126
19 CoreFoundation 0x33b0639e 0x33af7000 + 62366 // CFRunLoopRunInMode + 0x62
20 Foundation 0x315deb7e 0x315da000 + 19326 // -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 0xfa
21 Foundation 0x315f852c 0x315da000 + 124204 // -[NSRunLoop(NSRunLoop) run] + 0x48
22 MailDataProvider 0x0430fdb6 0x430e000 + 7606 // -[_MFMailDataProviderThread _runServer] + 0xb2
23 Foundation 0x315eaa8a 0x315da000 + 68234 // -[NSThread main] + 0x42
24 Foundation 0x3167e59a 0x315da000 + 673178 // __NSThread__main__ + 0x412
25 libsystem_c.dylib 0x349ebc16 0x349dc000 + 64534 // _pthread_start + 0x13a
26 libsystem_c.dylib 0x349ebad0 0x349dc000 + 64208 // thread_start + 0x0
Thread 0 crashed with ARM Thread State:
r0: 0x00000000 r1: 0x00000000 r2: 0x00000001 r3: 0x00000000
r4: 0x00000006 r5: 0x3f124ce8 r6: 0x00000002 r7: 0x2fe299a4
r8: 0x00000001 r9: 0x35ed5a4a r10: 0x00000000 r11: 0x00347a20
ip: 0x00000148 sp: 0x2fe29998 lr: 0x34a29f5b pc: 0x3617d32c
cpsr: 0x000f0010
Binary Images:
0x2b000 - 0x230fff SpringBoard armv7 &lt;7506c20d86da3f1dbe9bf38f8bda253d&gt; /System/Library/CoreServices/SpringBoard.app/SpringBoard
0x2bc000 - 0x2bcfff +MobileSubstrate.dylib armv6 &lt;5b28f15272a4394ca1aaf2d755a99412&gt; /Library/MobileSubstrate/MobileSubstrate.dylib
0x2db000 - 0x2ddfff Backlight armv7 &lt;cf8b322a0143350eb7bb7146c90c72d9&gt; /System/Library/HIDPlugins/Backlight.plugin/Backlight
0x2fa000 - 0x2fbfff +SubstrateLoader.dylib armv6 &lt;f3b84768c452327a9e173106425e2a38&gt; /Library/Frameworks/CydiaSubstrate.framework/Libraries/SubstrateLoader.dylib
0x427000 - 0x452fff +Activator.dylib armv6 &lt;f9312f7cbf66302eb7ec8eb10e9bcf90&gt; /Library/MobileSubstrate/DynamicLibraries/Activator.dylib
0x4e7000 - 0x4ebfff +AppList.dylib armv6 &lt;ee905d084b7a3ee1b8d5ddf3a0d2dc2d&gt; /Library/MobileSubstrate/DynamicLibraries/AppList.dylib
0x4f0000 - 0x4f6fff +Backgrounder.dylib arm &lt;dd5578403af175ef3c329e4e83e85b97&gt; /Library/MobileSubstrate/DynamicLibraries/Backgrounder.dylib
0x4fa000 - 0x4fdfff libsubstrate.dylib armv6 &lt;5ac0b5d17c9732a3a9ba678d738790c5&gt; /usr/lib/libsubstrate.dylib
0x17b3000 - 0x17b3fff +BackwardCompatibility.dylib arm /Library/MobileSubstrate/DynamicLibraries/BackwardCompatibility.dylib
0x17b6000 - 0x17b6fff +BugFix_DuplicateIcons.dylib arm &lt;f7911dae82838449874ecd3702aa4ae5&gt; /Library/MobileSubstrate/DynamicLibraries/BugFix_DuplicateIcons.dylib
0x17b9000 - 0x17b9fff +BugFix_StuckPages.dylib arm &lt;f4529213f1933e7b747144c5b38f6d4e&gt; /Library/MobileSubstrate/DynamicLibraries/BugFix_StuckPages.dylib
0x17bc000 - 0x17bffff +CyDelete.dylib armv6 &lt;87085dc54e1f324cad66b1e07d504fee&gt; /Library/MobileSubstrate/DynamicLibraries/CyDelete.dylib
0x17c9000 - 0x17cbfff +DisplayStack.dylib armv6 &lt;8f7495d051871fedf1228ceaefa89d4d&gt; /Library/MobileSubstrate/DynamicLibraries/DisplayStack.dylib
0x17ce000 - 0x17d2fff +IconSupport.dylib arm &lt;6778a843b88fdadbafdb9db4179550d9&gt; /Library/MobileSubstrate/DynamicLibraries/IconSupport.dylib
0x17d5000 - 0x17d7fff +RotationInhibitor.dylib armv6 &lt;a5b6f693664c303d88595063435509d2&gt; /Library/MobileSubstrate/DynamicLibraries/RotationInhibitor.dylib
0x17da000 - 0x17e5fff +SBSettings.dylib armv6 &lt;943484dfa081c192ec89f3f2329b085a&gt; /Library/MobileSubstrate/DynamicLibraries/SBSettings.dylib
0x17f2000 - 0x17f3fff +SpringBoardAccess.dylib arm &lt;a015d76776da9888e069c8d6f143d765&gt; /Library/MobileSubstrate/DynamicLibraries/SpringBoardAccess.dylib
0x17f6000 - 0x1806fff +WinterBoard.dylib arm /Library/MobileSubstrate/DynamicLibraries/WinterBoard.dylib
0x181e000 - 0x1820fff +libhide.dylib arm &lt;bba657e1bd09bab5f888545db2928786&gt; /Library/MobileSubstrate/DynamicLibraries/libhide.dylib
0x1823000 - 0x1829fff +libstatusbar.dylib armv6 &lt;fe21097b2cb83481a70c9ab877af55e3&gt; /Library/MobileSubstrate/DynamicLibraries/libstatusbar.dylib
0x182d000 - 0x182efff +sandcastle.dylib armv6 &lt;ad65601afce130f3abf98b3279fad9ce&gt; /Library/MobileSubstrate/DynamicLibraries/sandcastle.dylib
0x1831000 - 0x1832fff +sandcastleclient.dylib armv6 &lt;d138ce2db8b033aba6119acf3d561535&gt; /Library/MobileSubstrate/DynamicLibraries/sandcastleclient.dylib
0x2ae7000 - 0x2af1fff AccessibilitySettingsLoader armv7 &lt;45d7c264810c364b976dba254572d73d&gt; /System/Library/AccessibilityBundles/AccessibilitySettingsLoader.bundle/AccessibilitySettingsLoader
0x2ce4000 - 0x2cf0fff MultitouchHID armv7 &lt;d203aed2bda137bb9cd5799e8d8fd480&gt; /System/Library/Extensions/AppleMultitouchSPI.kext/PlugIns/MultitouchHID.plugin/MultitouchHID
0x3c86000 - 0x3c87fff EKCalendar armv7 &lt;4c8273a6631135ee817d250488e2c3a8&gt; /System/Library/SpringBoardPlugins/EKCalendar.servicebundle/EKCalendar
0x430e000 - 0x4315fff MailDataProvider armv7 &lt;ccec053d8f2a3893840565eb19e2401f&gt; /System/Library/BulletinBoardPlugins/MailDataProvider.bundle/MailDataProvider
0x431d000 - 0x4320fff PushDataProviderFactory armv7 &lt;4d06e894046a33818ac5458a29a744f1&gt; /System/Library/BulletinBoardPlugins/PushDataProviderFactory.bundle/PushDataProviderFactory
0x438e000 - 0x439ffff Riven armv7 &lt;388ff5b370123c56839f20af9c1b9ed6&gt; /System/Library/TextInput/Riven.bundle/Riven
0x43b2000 - 0x43befff WiFiPicker armv7 &lt;563cf37a7e5b39de8c2fe7e7428a8b0e&gt; /System/Library/SpringBoardPlugins/WiFiPicker.servicebundle/WiFiPicker
0x4614000 - 0x4614fff +Toggle.dylib arm &lt;54d0f58da75972e038883defabe4dcc6&gt; /var/mobile/Library/SBSettings/Toggles/3G/Toggle.dylib
0x4617000 - 0x4618fff +Toggle.dylib arm &lt;b00c29872f767a3a993ef2e7724af2e8&gt; /var/mobile/Library/SBSettings/Toggles/Airplane/Toggle.dylib
0x461b000 - 0x461bfff +Toggle.dylib arm &lt;c4d71529a1d51704706fffa892c4f5d4&gt; /var/mobile/Library/SBSettings/Toggles/Bluetooth/Toggle.dylib
0x4622000 - 0x4622fff +Toggle.dylib arm &lt;9d55da6026ab3f9574a9c9950794f0c0&gt; /var/mobile/Library/SBSettings/Toggles/Data/Toggle.dylib
0x4625000 - 0x4625fff +Toggle.dylib arm &lt;9f0179854929b62ee16f5aeed620c303&gt; /var/mobile/Library/SBSettings/Toggles/Location/Toggle.dylib
0x4628000 - 0x4628fff +Toggle.dylib arm &lt;d7a840f7a771adea76922c6ecd09de95&gt; /var/mobile/Library/SBSettings/Toggles/SSH/Toggle.dylib
0x462b000 - 0x462cfff +Toggle.dylib arm &lt;d150b7865d56c66aac4ea716877e5ad1&gt; /var/mobile/Library/SBSettings/Toggles/Syslog/Toggle.dylib
0x462f000 - 0x4631fff +Toggle.dylib arm &lt;1d40433bbdf09c726cc36edd0894bc03&gt; /var/mobile/Library/SBSettings/Toggles/Wi-Fi/Toggle.dylib
0x46b8000 - 0x46bbfff GameKitDataProvider armv7 &lt;2f8d756ef0223c02b924ddd707315c5b&gt; /System/Library/BulletinBoardPlugins/GameKitDataProvider.bundle/GameKitDataProvider
0x46bf000 - 0x46c8fff ChatKit armv7 &lt;9ef7d722cc04353aad958c6e2f4a3cf7&gt; /System/Library/SpringBoardPlugins/ChatKit.servicebundle/ChatKit
0x592a000 - 0x5934fff CalendarProvider armv7 &lt;199f52167001328a8e76735cd1f6c12a&gt; /System/Library/BulletinBoardPlugins/CalendarProvider.bundle/CalendarProvider
0x2fe2a000 - 0x2fe4bfff dyld armv7 &lt;be7c0b491a943054ad12eb5060f1da06&gt; /usr/lib/dyld
0x3025f000 - 0x302cffff CoreImage armv7 &lt;b1d0678497f43769840f173c0f9dce20&gt; /System/Library/Frameworks/CoreImage.framework/CoreImage
0x302d0000 - 0x302d3fff CoreTime armv7 &lt;e2f02260f2a63359b9a0a47c69f59c9e&gt; /System/Library/PrivateFrameworks/CoreTime.framework/CoreTime
0x302d4000 - 0x302f9fff OpenCL armv7 &lt;e1d5bfcdb59934b0923b9307c75e7457&gt; /System/Library/PrivateFrameworks/OpenCL.framework/OpenCL
0x30324000 - 0x3033afff DictionaryServices armv7 &lt;5bbab664f97932a79a1566fda3a4383e&gt; /System/Library/PrivateFrameworks/DictionaryServices.framework/DictionaryServices
0x30345000 - 0x3034afff libcopyfile.dylib armv7 &lt;9072462f28af3665875b3ecaba002c00&gt; /usr/lib/system/libcopyfile.dylib
0x303d7000 - 0x3040cfff SystemConfiguration armv7 &lt;753be0ebdcb13b24b1a4adcdc94d6bd9&gt; /System/Library/Frameworks/SystemConfiguration.framework/SystemConfiguration
0x30418000 - 0x30461fff libc++.1.dylib armv7 &lt;ad15503487243836b7c296f3439ba0c1&gt; /usr/lib/libc++.1.dylib
0x30462000 - 0x30469fff MailServices armv7 &lt;a5e048e513b237b78d62fb3996a85fa9&gt; /System/Library/PrivateFrameworks/MailServices.framework/MailServices
0x30471000 - 0x3047dfff libz.1.dylib armv7 &lt;eef915ed9b2c3433b03fd9030957b945&gt; /usr/lib/libz.1.dylib
0x3048e000 - 0x3049afff CoreVideo armv7 &lt;474c89eb09fe3464851a20d76052341b&gt; /System/Library/Frameworks/CoreVideo.framework/CoreVideo
0x3049b000 - 0x3049efff CaptiveNetwork armv7 &lt;c3a5b1659eb0302eb205498ffacb09f1&gt; /System/Library/PrivateFrameworks/CaptiveNetwork.framework/CaptiveNetwork
0x3049f000 - 0x304a5fff BluetoothManager armv7 &lt;9d85a2e3d7a135ed957646d454d4d7ea&gt; /System/Library/PrivateFrameworks/BluetoothManager.framework/BluetoothManager
0x304a6000 - 0x304acfff liblockdown.dylib armv7 &lt;bfaf7fb16e5a3b2ea07c47b8b2f2b64e&gt; /usr/lib/liblockdown.dylib
0x304ad000 - 0x304c6fff ICE armv7 &lt;719da3c65c3c3e0e92f61ee0ff3ca4e1&gt; /System/Library/PrivateFrameworks/GameKitServices.framework/Frameworks/ICE.framework/ICE
0x304c7000 - 0x304e6fff libSystem.B.dylib armv7 &lt;31a0ffbb18bf3a28b46fd286733e7d9f&gt; /usr/lib/libSystem.B.dylib
0x3053c000 - 0x3060cfff AVConference armv7 &lt;a3f88e99e17737abaed00f70f7a8bcf9&gt; /System/Library/PrivateFrameworks/GameKitServices.framework/Frameworks/AVConference.framework/AVConference
0x30628000 - 0x30629fff libremovefile.dylib armv7 &lt;9c8cee9652453241ac1fc99eab05c40a&gt; /usr/lib/system/libremovefile.dylib
0x3062d000 - 0x30670fff ImageCapture armv7 &lt;f332ba0dfb453a3a968506a4db4d26a6&gt; /System/Library/PrivateFrameworks/ImageCapture.framework/ImageCapture
0x30671000 - 0x306c8fff CoreAudio armv7 &lt;2e4975a2156e328585f2a478e80704fc&gt; /System/Library/Frameworks/CoreAudio.framework/CoreAudio
0x306c9000 - 0x30775fff MediaControlSender armv7 &lt;4c0982b21ecf35aead8e0bef55d842b0&gt; /System/Library/PrivateFrameworks/MediaControlSender.framework/MediaControlSender
0x30776000 - 0x3077efff VisualVoicemail armv7 &lt;d0be2090ddab3541ad5d8d3adab2c1ab&gt; /System/Library/PrivateFrameworks/VisualVoicemail.framework/VisualVoicemail
0x30970000 - 0x30998fff IMDPersistence armv7 &lt;206bf0e112aa35e99dda1f4efc987363&gt; /System/Library/PrivateFrameworks/IMCore.framework/Frameworks/IMDPersistence.framework/IMDPersistence
0x30999000 - 0x30a54fff AVFoundation armv7 &lt;c971a925b82934f8881283aabb2992f5&gt; /System/Library/Frameworks/AVFoundation.framework/AVFoundation
0x30a62000 - 0x30a63fff libIOAccessoryManager.dylib armv7 &lt;b45203447767375daabecfcf989e2823&gt; /usr/lib/libIOAccessoryManager.dylib
0x30a64000 - 0x30a92fff CoreMediaStream armv7 &lt;bd4a539426f2347b86f2faf33101cfd3&gt; /System/Library/PrivateFrameworks/CoreMediaStream.framework/CoreMediaStream
0x30a93000 - 0x30adefff CoreLocation armv7 &lt;e959d4dd596b31eeaa49c8c0156b1e12&gt; /System/Library/Frameworks/CoreLocation.framework/CoreLocation
0x30adf000 - 0x31023fff FaceCoreLight armv7 &lt;cc2edb3645d2390dbca5471d35f1bf6e&gt; /System/Library/PrivateFrameworks/FaceCoreLight.framework/FaceCoreLight
0x31024000 - 0x31035fff DataAccessExpress armv7 &lt;6bc443b0f87e338698cac9e5a96e8f8f&gt; /System/Library/PrivateFrameworks/DataAccessExpress.framework/DataAccessExpress
0x31036000 - 0x31079fff libcommonCrypto.dylib armv7 &lt;be9a231cfe6e3ae387abb444a098bce9&gt; /usr/lib/system/libcommonCrypto.dylib
0x310ab000 - 0x310acfff libsystem_sandbox.dylib armv7 &lt;b8612b4ce18535aaa94f4b75c730e090&gt; /usr/lib/system/libsystem_sandbox.dylib
0x310ad000 - 0x31153fff AddressBookUI armv7 &lt;d785fe33cd263f5aba861ad919c66924&gt; /System/Library/Frameworks/AddressBookUI.framework/AddressBookUI
0x31154000 - 0x3115bfff SpringBoardUI armv7 &lt;dbbf397d3190322d9d9a1f9ca48665e8&gt; /System/Library/PrivateFrameworks/SpringBoardUI.framework/SpringBoardUI
0x3124a000 - 0x31254fff AssistantUI armv7 &lt;539c347ae36f3f8f8c085750c8d5203c&gt; /System/Library/PrivateFrameworks/AssistantUI.framework/AssistantUI
0x312cc000 - 0x312dffff Notes armv7 &lt;b2cb7346cb2b36eca53d22534c53b508&gt; /System/Library/PrivateFrameworks/Notes.framework/Notes
0x31323000 - 0x31360fff FTServices armv7 &lt;fc9e7d223d3f33898603cfba115f5094&gt; /System/Library/PrivateFrameworks/FTServices.framework/FTServices
0x31383000 - 0x31384fff BackgroundTaskAgent armv7 &lt;642f8c060ce2399e8609b2b25a0690a0&gt; /System/Library/PrivateFrameworks/BackgroundTaskAgent.framework/BackgroundTaskAgent
0x31385000 - 0x313c5fff libGLImage.dylib armv7 &lt;9440420d838a382caa175399d74a5044&gt; /System/Library/Frameworks/OpenGLES.framework/libGLImage.dylib
0x31437000 - 0x3146cfff DataAccess armv7 &lt;432578d415dd3398b3487f003b3100ac&gt; /System/Library/PrivateFrameworks/DataAccess.framework/DataAccess
0x3146d000 - 0x314effff MapKit armv7 &lt;1dd7d48dbbb6395ca77b97c2db4ae36e&gt; /System/Library/Frameworks/MapKit.framework/MapKit
0x314fb000 - 0x3150afff OpenGLES armv7 &lt;6d1afb451f50310895ec59864739e781&gt; /System/Library/Frameworks/OpenGLES.framework/OpenGLES
0x3150b000 - 0x31515fff libvMisc.dylib armv7 &lt;b93ee3136d1c3d44b1e513a56bb0f86c&gt; /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libvMisc.dylib
0x315be000 - 0x315c7fff libMobileGestalt.dylib armv7 &lt;bf8d7c30f11a393a8adf4c8277e65aa3&gt; /usr/lib/libMobileGestalt.dylib
0x315da000 - 0x31758fff Foundation armv7 &lt;ce466f428d953caaac6641d186665809&gt; /System/Library/Frameworks/Foundation.framework/Foundation
0x3175b000 - 0x31767fff AssetsLibrary armv7 &lt;7837ca13e3353f17a927bc93c65061e6&gt; /System/Library/Frameworks/AssetsLibrary.framework/AssetsLibrary
0x3177b000 - 0x3178efff DataDetectorsCore armv7 &lt;2df5f2299dc8351f80ea3e79de8706a9&gt; /System/Library/PrivateFrameworks/DataDetectorsCore.framework/DataDetectorsCore
0x3178f000 - 0x31940fff MediaPlayer armv7 &lt;ef8f1f4574823f41899569ea48367903&gt; /System/Library/Frameworks/MediaPlayer.framework/MediaPlayer
0x31955000 - 0x31b11fff MusicLibrary armv7 &lt;7be04d376ebc3d419ad408284cef681d&gt; /System/Library/PrivateFrameworks/MusicLibrary.framework/MusicLibrary
0x31b12000 - 0x31b16fff IOMobileFramebuffer armv7 &lt;c2e6bd6dafde3097b47bc255a8c871ef&gt; /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/IOMobileFramebuffer
0x31b6a000 - 0x31c5afff QuartzCore armv7 &lt;ff595b1a042933249466e92433e1af6f&gt; /System/Library/Frameworks/QuartzCore.framework/QuartzCore
0x31c5b000 - 0x31c85fff ACTFramework armv7 &lt;480a714d9901392cabc55d10ed4485a7&gt; /System/Library/PrivateFrameworks/ACTFramework.framework/ACTFramework
0x31dbf000 - 0x31e88fff Celestial armv7 &lt;c18e76311fc33016be930da83050b96d&gt; /System/Library/PrivateFrameworks/Celestial.framework/Celestial
0x31e8b000 - 0x31ea1fff VoiceServices armv7 &lt;5bdff32282a33333b9c90582c854d82f&gt; /System/Library/PrivateFrameworks/VoiceServices.framework/VoiceServices
0x31ef4000 - 0x31f0cfff ChunkingLibrary armv7 &lt;790821d1c99e34c0b966451ac3e596b3&gt; /System/Library/PrivateFrameworks/ChunkingLibrary.framework/ChunkingLibrary
0x31f0f000 - 0x31f53fff MobileCoreServices armv7 &lt;9a79a2d389ba35389a30782ed01c46dd&gt; /System/Library/Frameworks/MobileCoreServices.framework/MobileCoreServices
0x31f54000 - 0x31f90fff AppSupport armv7 &lt;de0c2fbb95f8383db43acfb44e9c66fe&gt; /System/Library/PrivateFrameworks/AppSupport.framework/AppSupport
0x31f91000 - 0x31fbdfff libtidy.A.dylib armv7 &lt;f0eca72c10c537fa89b17fd97e003faf&gt; /usr/lib/libtidy.A.dylib
0x31fec000 - 0x3201ffff MIME armv7 &lt;0c29ae0826c53ebbaf9424b389016b68&gt; /System/Library/PrivateFrameworks/MIME.framework/MIME
0x32020000 - 0x3203efff BulletinBoard armv7 &lt;c476f75a282631c993e600a9201078e4&gt; /System/Library/PrivateFrameworks/BulletinBoard.framework/BulletinBoard
0x32052000 - 0x32057fff libsystem_dnssd.dylib armv7 &lt;4d8b38f1cb603f0d8af78c56c485f05a&gt; /usr/lib/system/libsystem_dnssd.dylib
0x320b7000 - 0x32100fff ManagedConfiguration armv7 &lt;05711081dd883c58a844c5f9c251e8c9&gt; /System/Library/PrivateFrameworks/ManagedConfiguration.framework/ManagedConfiguration
0x32101000 - 0x3216efff Conference armv7 &lt;dcb8a5f28f6532adac5065dece52dc0f&gt; /System/Library/PrivateFrameworks/Conference.framework/Conference
0x321a1000 - 0x321a2fff libsystem_blocks.dylib armv7 &lt;4bb9797771d037879bec814fe750d86d&gt; /usr/lib/system/libsystem_blocks.dylib
0x321a3000 - 0x321b2fff SpringBoardServices armv7 &lt;79f1564c1b23303eb3b7db67f9375228&gt; /System/Library/PrivateFrameworks/SpringBoardServices.framework/SpringBoardServices
0x321b3000 - 0x321bffff libCRFSuite.dylib armv7 &lt;ea460e3f1ac338a9885d5752864dbffb&gt; /usr/lib/libCRFSuite.dylib
0x321c0000 - 0x321cffff MobileDeviceLink armv7 &lt;09c637a85e3d3af488e59ced95a5a916&gt; /System/Library/PrivateFrameworks/MobileDeviceLink.framework/MobileDeviceLink
0x321da000 - 0x321e6fff Accounts armv7 &lt;d45636e9d2263676b17c2c33ec7e91d3&gt; /System/Library/Frameworks/Accounts.framework/Accounts
0x321e7000 - 0x322b6fff libGLProgrammability.dylib armv7 &lt;cb91cd9952e7371a9659da26034c8324&gt; /System/Library/Frameworks/OpenGLES.framework/libGLProgrammability.dylib
0x322b7000 - 0x3234efff PhotoLibraryServices armv7 &lt;2102aeb03f8931ce859b06601962b54f&gt; /System/Library/PrivateFrameworks/PhotoLibraryServices.framework/PhotoLibraryServices
0x3234f000 - 0x32368fff Twitter armv7 &lt;410df62019ed31a8b3997d9e837aa7c4&gt; /System/Library/Frameworks/Twitter.framework/Twitter
0x32369000 - 0x3236dfff AggregateDictionary armv7 &lt;cfd957904957310381369729bfd9b2b0&gt; /System/Library/PrivateFrameworks/AggregateDictionary.framework/AggregateDictionary
0x3236e000 - 0x325c8fff MediaToolbox armv7 &lt;ab91ec33f2b23606bd0443163beff710&gt; /System/Library/PrivateFrameworks/MediaToolbox.framework/MediaToolbox
0x32608000 - 0x3266bfff IMCore armv7 &lt;c235020b86123e95820f7323916023aa&gt; /System/Library/PrivateFrameworks/IMCore.framework/IMCore
0x32670000 - 0x329e1fff TextInput armv7 &lt;64d1227219b03c51ba4854ec2f79c335&gt; /System/Library/PrivateFrameworks/TextInput.framework/TextInput
0x32db5000 - 0x32db5fff liblangid.dylib armv7 &lt;342170169bf232a0888912f5ef97112d&gt; /usr/lib/liblangid.dylib
0x32db6000 - 0x32e86fff WebKit armv7 &lt;74661b1bf4613aafb827bfe0134ed92b&gt; /System/Library/PrivateFrameworks/WebKit.framework/WebKit
0x32e87000 - 0x32f5efff CFNetwork armv7 &lt;6fbc9f187eaa30009780e70288c9f289&gt; /System/Library/Frameworks/CFNetwork.framework/CFNetwork
0x32f5f000 - 0x32f63fff FTClientServices armv7 &lt;8f823e791c9e37b4b47323bb0286e86c&gt; /System/Library/PrivateFrameworks/FTClientServices.framework/FTClientServices
0x32f68000 - 0x32fa2fff SAObjects armv7 &lt;2332d449a3193cf095060ae180946a33&gt; /System/Library/PrivateFrameworks/SAObjects.framework/SAObjects
0x32fa5000 - 0x32fa8fff libcompiler_rt.dylib armv7 &lt;414332f9a55238bab2cbec323e0fc8da&gt; /usr/lib/system/libcompiler_rt.dylib
0x32fa9000 - 0x32facfff libsystem_network.dylib armv7 &lt;b18e0a845b1e317c8abcf6b5d06b29a0&gt; /usr/lib/system/libsystem_network.dylib
0x33047000 - 0x33048fff CoreSurface armv7 &lt;fcb6a869daef3a3abc4300c28b218e9f&gt; /System/Library/PrivateFrameworks/CoreSurface.framework/CoreSurface
0x3304a000 - 0x3304afff LegacyHandle armv7 &lt;ac83c57186803c4abda5cad99b34c317&gt; /System/Library/PrivateFrameworks/GameKitServices.framework/Frameworks/LegacyHandle.framework/LegacyHandle
0x3304b000 - 0x3304bfff libCVMSPluginSupport.dylib armv7 &lt;85582e1094633fccb52b50ca13c5a5d0&gt; /System/Library/Frameworks/OpenGLES.framework/libCVMSPluginSupport.dylib
0x33062000 - 0x33082fff libxslt.1.dylib armv7 &lt;f37418b7e89137bba433677d61cd779d&gt; /usr/lib/libxslt.1.dylib
0x33083000 - 0x33092fff GenerationalStorage armv7 &lt;c581bffc87013530b3c2d017142395e6&gt; /System/Library/PrivateFrameworks/GenerationalStorage.framework/GenerationalStorage
0x33093000 - 0x33093fff libunwind.dylib armv7 &lt;d21222aad8c93d6c9580f9bf47071946&gt; /usr/lib/system/libunwind.dylib
0x330d8000 - 0x330dafff libsp.dylib armv7 &lt;161d57cdb91438fbb5fb975a66bc3666&gt; /usr/lib/libsp.dylib
0x3311f000 - 0x33126fff AssetsLibraryServices armv7 &lt;c0093954f6ee329aa6b4848215bcb8c0&gt; /System/Library/PrivateFrameworks/AssetsLibraryServices.framework/AssetsLibraryServices
0x33127000 - 0x331d5fff Message armv7 &lt;0d844e0108b1301bb08a74df3e3589b5&gt; /System/Library/PrivateFrameworks/Message.framework/Message
0x331d6000 - 0x331dbfff CrashReporterSupport armv7 &lt;c3062554536438f9874c88363df7f60b&gt; /System/Library/PrivateFrameworks/CrashReporterSupport.framework/CrashReporterSupport
0x331dc000 - 0x33231fff GameKitServices armv7 &lt;740f478efc1a30398744581bfeb02c5a&gt; /System/Library/PrivateFrameworks/GameKitServices.framework/GameKitServices
0x333c2000 - 0x333d4fff AssistantServices armv7 &lt;e0385ea92a063c15ac0c952e89e020d5&gt; /System/Library/PrivateFrameworks/AssistantServices.framework/AssistantServices
0x333ea000 - 0x33425fff libCGFreetype.A.dylib armv7 &lt;753daf497ca736739a30126661a522f1&gt; /System/Library/Frameworks/CoreGraphics.framework/Resources/libCGFreetype.A.dylib
0x33430000 - 0x33437fff ProtocolBuffer armv7 &lt;6ca7dca9370132a2a592356bf9f2170b&gt; /System/Library/PrivateFrameworks/ProtocolBuffer.framework/ProtocolBuffer
0x33438000 - 0x33474fff IMFoundation armv7 &lt;d93ec1a0f854355da1e4f8aca176e749&gt; /System/Library/PrivateFrameworks/IMCore.framework/Frameworks/IMFoundation.framework/IMFoundation
0x33475000 - 0x334c6fff libstdc++.6.dylib armv7 &lt;dc2061145c1a3307829d4f3bfc547c1a&gt; /usr/lib/libstdc++.6.dylib
0x334c7000 - 0x3365ffff CoreData armv7 &lt;dd6d139d99e5309f9df33f7b6a044b16&gt; /System/Library/Frameworks/CoreData.framework/CoreData
0x33660000 - 0x336b1fff CoreText armv7 &lt;23150093d39b393e9bc5f8230176df47&gt; /System/Library/Frameworks/CoreText.framework/CoreText
0x33820000 - 0x3385ffff QuickLook armv7 &lt;fdc0e38e19f9316fb0923c390e8d3ccd&gt; /System/Library/Frameworks/QuickLook.framework/QuickLook
0x338b5000 - 0x338b7fff MobileInstallation armv7 &lt;4ccf76f0e6cb3cd7b4e0087c2f284a1d&gt; /System/Library/PrivateFrameworks/MobileInstallation.framework/MobileInstallation
0x338b8000 - 0x338befff MobileKeyBag armv7 &lt;f5633749a1c83058a28cd7d0b488e19f&gt; /System/Library/PrivateFrameworks/MobileKeyBag.framework/MobileKeyBag
0x338bf000 - 0x3391afff StoreServices armv7 &lt;1463a9f90fbd3d349544cf016e1ddd46&gt; /System/Library/PrivateFrameworks/StoreServices.framework/StoreServices
0x3391b000 - 0x33a1bfff VideoProcessing armv7 &lt;004091713a5731d7a84dcf07d77f8446&gt; /System/Library/PrivateFrameworks/VideoProcessing.framework/VideoProcessing
0x33a1c000 - 0x33af6fff vImage armv7 &lt;42a5e58ff1b9350cad90de36bd3ceb09&gt; /System/Library/Frameworks/Accelerate.framework/Frameworks/vImage.framework/vImage
0x33af7000 - 0x33c0efff CoreFoundation armv7 &lt;de9eefc6109735369cfd8f3de9895da0&gt; /System/Library/Frameworks/CoreFoundation.framework/CoreFoundation
0x33c0f000 - 0x33c13fff libcache.dylib armv7 &lt;4511f0ec5b713636aaade7245a12553c&gt; /usr/lib/system/libcache.dylib
0x33cb8000 - 0x33ccefff libmis.dylib armv7 &lt;fd046316dedc34dd81a6601ea3b1e8a6&gt; /usr/lib/libmis.dylib
0x33e2a000 - 0x33e66fff iCalendar armv7 &lt;59d80290d8733df8a6310da65b497fc9&gt; /System/Library/PrivateFrameworks/iCalendar.framework/iCalendar
0x33e67000 - 0x33e71fff libbz2.1.0.dylib armv7 &lt;28583efb9f1b38e7ae83c667b07dbd08&gt; /usr/lib/libbz2.1.0.dylib
0x33f1a000 - 0x346d1fff WebCore armv7 &lt;7137e0ea008f3a3e8ae9e57f96d34d1d&gt; /System/Library/PrivateFrameworks/WebCore.framework/WebCore
0x347df000 - 0x34802fff PrintKit armv7 &lt;279fb51deec3377ab9f820af2da4d915&gt; /System/Library/PrivateFrameworks/PrintKit.framework/PrintKit
0x34956000 - 0x3495afff libAccessibility.dylib armv7 &lt;ee734c0e964934a887a66d170270b114&gt; /usr/lib/libAccessibility.dylib
0x349b4000 - 0x349b9fff ApplePushService armv7 &lt;2e620a6e8ee8387ba2771cfd7870c90e&gt; /System/Library/PrivateFrameworks/ApplePushService.framework/ApplePushService
0x349dc000 - 0x34a69fff libsystem_c.dylib armv7 &lt;1707c3cf3c5b3045af4bed38ff8420a6&gt; /usr/lib/system/libsystem_c.dylib
0x34ae0000 - 0x34c04fff JavaScriptCore armv7 &lt;24ff2747b3973aecb9c37960eba5ff4d&gt; /System/Library/PrivateFrameworks/JavaScriptCore.framework/JavaScriptCore
0x34c1a000 - 0x350b3fff UIKit armv7 &lt;97b527cd6fba35c6bb39263e0f362223&gt; /System/Library/Frameworks/UIKit.framework/UIKit
0x350b8000 - 0x35150fff EventKit armv7 &lt;f340aafa660d308a8cd86fd180aeaad9&gt; /System/Library/Frameworks/EventKit.framework/EventKit
0x35151000 - 0x35154fff ActorKit armv7 &lt;8c167170891238b3940f9f54105b6eb9&gt; /System/Library/PrivateFrameworks/ActorKit.framework/ActorKit
0x35159000 - 0x3515ffff XPCObjects armv7 &lt;efaf263941313a1cb0e4908e46beee95&gt; /System/Library/PrivateFrameworks/XPCObjects.framework/XPCObjects
0x35174000 - 0x351adfff VideoToolbox armv7 &lt;49f9f09f23f7396b94a29bb1280759fe&gt; /System/Library/PrivateFrameworks/VideoToolbox.framework/VideoToolbox
0x351ae000 - 0x351b9fff AppleFSCompression armv7 &lt;a88014f124993d0da33b7e7bb69128df&gt; /System/Library/PrivateFrameworks/AppleFSCompression.framework/AppleFSCompression
0x351bc000 - 0x351d2fff EAP8021X armv7 &lt;16801802d86e3c479f3034034192faed&gt; /System/Library/PrivateFrameworks/EAP8021X.framework/EAP8021X
S
Sean71596
Michigan
Still Crash Log-
0x351d6000 - 0x351f0fff MobileBackup armv7 &lt;5be6fc00a1ea3725a8b6b926e12bbe24&gt; /System/Library/PrivateFrameworks/MobileBackup.framework/MobileBackup
0x351f1000 - 0x3523afff CoreMedia armv7 &lt;d585cf4e0cfa34fa8beaa43b06a4bcd7&gt; /System/Library/Frameworks/CoreMedia.framework/CoreMedia
0x3523b000 - 0x35246fff ExternalAccessory armv7 &lt;076affef003933e38eca208e7e48d184&gt; /System/Library/Frameworks/ExternalAccessory.framework/ExternalAccessory
0x35279000 - 0x35279fff libkeymgr.dylib armv7 &lt;791bb8b832943b2392c0c35228f52e09&gt; /usr/lib/system/libkeymgr.dylib
0x3529f000 - 0x352a9fff SMSCTServer armv7 &lt;7e7b3b8279893d2bb30e51b90400dc53&gt; /System/Library/PrivateFrameworks/SMSCTServer.framework/SMSCTServer
0x352c3000 - 0x35389fff libobjc.A.dylib armv7 &lt;ebbb32df194b331e9b3dc14e40f46833&gt; /usr/lib/libobjc.A.dylib
0x3538a000 - 0x3538ffff libGPUSupportMercury.dylib armv7 &lt;2066fe9b4ee73d1d83f5801b6d0bb432&gt; /System/Library/PrivateFrameworks/GPUSupport.framework/libGPUSupportMercury.dylib
0x35390000 - 0x353a1fff libxpc.dylib armv7 &lt;7d49e385ee5d3e7eb08d06525abd6435&gt; /usr/lib/system/libxpc.dylib
0x353e0000 - 0x353e1fff libdnsinfo.dylib armv7 &lt;dbd1e77a4beb309d8f160d927d442467&gt; /usr/lib/system/libdnsinfo.dylib
0x353f1000 - 0x353f2fff libdyld.dylib armv7 &lt;f1963e7ef64e39a58ec1e39ed7c74849&gt; /usr/lib/system/libdyld.dylib
0x353f4000 - 0x354a2fff ChatKit armv7 &lt;a64ea83dfaa5363ca18adaeed7e2bd92&gt; /System/Library/PrivateFrameworks/ChatKit.framework/ChatKit
0x354a3000 - 0x3551cfff ProofReader armv7 &lt;09d057676f6837cd9e7a735444b67e77&gt; /System/Library/PrivateFrameworks/ProofReader.framework/ProofReader
0x3551f000 - 0x3551ffff libgcc_s.1.dylib armv7 &lt;69d8dab7388b33d38b30708fd6b6a340&gt; /usr/lib/libgcc_s.1.dylib
0x35552000 - 0x35555fff libmacho.dylib armv7 &lt;3237bc9c109e3354bc4b38b957243f31&gt; /usr/lib/system/libmacho.dylib
0x35556000 - 0x35563fff libbsm.0.dylib armv7 &lt;a6414b0a5fd53df58c4f0b2f8878f81f&gt; /usr/lib/libbsm.0.dylib
0x3556e000 - 0x3557efff Search armv7 &lt;99c733d279973b03b5c95cead8167208&gt; /System/Library/PrivateFrameworks/Search.framework/Search
0x355b0000 - 0x3570dfff libmecabra.dylib armv7 &lt;170c82a3c716372abe7ae0aae96d4805&gt; /usr/lib/libmecabra.dylib
0x3571c000 - 0x3573cfff SoftwareUpdateServices armv7 &lt;e3b23933897b3b81bb5576a0e6be587a&gt; /System/Library/PrivateFrameworks/SoftwareUpdateServices.framework/SoftwareUpdateServices
0x35743000 - 0x3574efff GraphicsServices armv7 &lt;4ec745ffb2e039faab4b39a30268f707&gt; /System/Library/PrivateFrameworks/GraphicsServices.framework/GraphicsServices
0x3574f000 - 0x3578cfff IOKit armv7 &lt;e5f727892ee034a4be04e6da608f413f&gt; /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x357d4000 - 0x35801fff MMCS armv7 &lt;dd4ddefe870130769ee59a67b6b747d6&gt; /System/Library/PrivateFrameworks/MMCS.framework/MMCS
0x358fa000 - 0x3590bfff AirTraffic armv7 &lt;187da49948ed3897aeac049cab658528&gt; /System/Library/PrivateFrameworks/AirTraffic.framework/AirTraffic
0x3590c000 - 0x3592ffff Bom armv7 &lt;0e6087f75a81345ea81751197ccb712c&gt; /System/Library/PrivateFrameworks/Bom.framework/Bom
0x35930000 - 0x35b0dfff AudioToolbox armv7 &lt;da4f78fd20fb3b42b1a8be4f383d9c12&gt; /System/Library/Frameworks/AudioToolbox.framework/AudioToolbox
0x35b21000 - 0x35b25fff AppleHDQGasGaugeHID armv7 &lt;4bbff4e73ed631589fdb65542d38bf2e&gt; /System/Library/Extensions/AppleHDQGasGaugeControl.kext/PlugIns/AppleHDQGasGaugeHID.plugin/AppleHDQGasGaugeHID
0x35b2c000 - 0x35baffff CoreMotion armv7 &lt;f4365ff3974b3049b3f04b3f55a46ae6&gt; /System/Library/Frameworks/CoreMotion.framework/CoreMotion
0x35bb0000 - 0x35bb6fff IAP armv7 &lt;f6a99995c7de3db8a52e9a35aac063bc&gt; /System/Library/PrivateFrameworks/IAP.framework/IAP
0x35bb7000 - 0x35e78fff libLAPACK.dylib armv7 &lt;5490a87fe5153771b9c67940292842ba&gt; /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libLAPACK.dylib
0x35e79000 - 0x35ec3fff CoreTelephony armv7 &lt;1f4cacb552533c948122cb180f4192b3&gt; /System/Library/Frameworks/CoreTelephony.framework/CoreTelephony
0x35ec4000 - 0x35eccfff Librarian armv7 &lt;389fa4539c77378ca5ae56cf77b7b339&gt; /System/Library/PrivateFrameworks/Librarian.framework/Librarian
0x35ecd000 - 0x35ecdfff Spotlight armv7 &lt;974145a98b5834249a06a4a19e250f2c&gt; /System/Library/PrivateFrameworks/Spotlight.framework/Spotlight
0x35ece000 - 0x35ed5fff libc++abi.dylib armv7 &lt;f769ce305c3033ee90e8c2ecc4846619&gt; /usr/lib/libc++abi.dylib
0x35ed6000 - 0x35f55fff libsqlite3.dylib armv7 &lt;af4718fee01734748c42f2214ab6883d&gt; /usr/lib/libsqlite3.dylib
0x35f56000 - 0x3605efff GameKit armv7 &lt;cc9aefab7a1b37048c1519fbe2b3bdf3&gt; /System/Library/Frameworks/GameKit.framework/GameKit
0x3605f000 - 0x36063fff ViceroyTrace armv7 &lt;30ad1c79e4da33beaeeddd8b3d99ed92&gt; /System/Library/PrivateFrameworks/GameKitServices.framework/Frameworks/ViceroyTrace.framework/ViceroyTrace
0x360d3000 - 0x3612cfff IMAVCore armv7 &lt;7bc289fcff2c38c7bb941c5e0bfb1178&gt; /System/Library/PrivateFrameworks/IMAVCore.framework/IMAVCore
0x36136000 - 0x3615ffff ToneLibrary armv7 &lt;c5e6997c2a0a38c5968cc476bdecc947&gt; /System/Library/PrivateFrameworks/ToneLibrary.framework/ToneLibrary
0x36160000 - 0x36162fff OAuth armv7 &lt;c2a13b4c4dfd34efb60e89dafa87273c&gt; /System/Library/PrivateFrameworks/OAuth.framework/OAuth
0x36164000 - 0x3616afff libnotify.dylib armv7 &lt;1e374857ac68370095ddbafe94f021a1&gt; /usr/lib/system/libnotify.dylib
0x3616c000 - 0x36182fff libsystem_kernel.dylib armv7 &lt;afd3cb06e20336dca2e5a6e11d080504&gt; /usr/lib/system/libsystem_kernel.dylib
0x36185000 - 0x361a8fff MobileSync armv7 &lt;be06df250fff368b92bc0a1defc6df9c&gt; /System/Library/PrivateFrameworks/MobileSync.framework/MobileSync
0x361ad000 - 0x361affff libCoreVMClient.dylib armv7 &lt;6ddb7cf8a93830628787a5b83eea0f1d&gt; /System/Library/Frameworks/OpenGLES.framework/libCoreVMClient.dylib
0x361b0000 - 0x361b8fff MobileWiFi armv7 &lt;f07cb8d6dadf36919bae8ef6e5ce1749&gt; /System/Library/PrivateFrameworks/MobileWiFi.framework/MobileWiFi
0x361c5000 - 0x3620ffff libvDSP.dylib armv7 &lt;d8489a4ce77933abac52394c43ff5513&gt; /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libvDSP.dylib
0x36212000 - 0x36214fff libCoreFSCache.dylib armv7 &lt;1ece4be587ca397b8f0494c56ed46976&gt; /System/Library/Frameworks/OpenGLES.framework/libCoreFSCache.dylib
0x3621d000 - 0x36254fff Security armv7 &lt;b89c9f6373f037f2a4801558f97b9a95&gt; /System/Library/Frameworks/Security.framework/Security
0x36257000 - 0x36274fff libsystem_info.dylib armv7 &lt;1e36ab94661c372bab5a801d68c79353&gt; /usr/lib/system/libsystem_info.dylib
0x36287000 - 0x36443fff ImageIO armv7 &lt;df300f66a317352e92354a8a48af3453&gt; /System/Library/Frameworks/ImageIO.framework/ImageIO
0x3646c000 - 0x364a6fff iTunesStore armv7 &lt;abf9395fcf8b3c13b9638b85541484c7&gt; /System/Library/PrivateFrameworks/iTunesStore.framework/iTunesStore
0x364a7000 - 0x3656dfff GLEngine armv7 &lt;0231a8c1fa3f3cfe82e83fc53c0cf5d8&gt; /System/Library/Frameworks/OpenGLES.framework/GLEngine.bundle/GLEngine
0x3656e000 - 0x365a1fff Preferences armv7 &lt;caa5c45e069a322480f19349edb59696&gt; /System/Library/PrivateFrameworks/Preferences.framework/Preferences
0x365a4000 - 0x365a9fff SMSBBPlugin armv7 &lt;1623dad5669031128821a8aadc020ccf&gt; /System/Library/BulletinBoardPlugins/SMSBBPlugin.bundle/SMSBBPlugin
0x365aa000 - 0x365b1fff SimpleKeyExchange armv7 &lt;bbeb306bd51b31eea7b133604e87535a&gt; /System/Library/PrivateFrameworks/GameKitServices.framework/Frameworks/SimpleKeyExchange.framework/SimpleKeyExchange
0x365b2000 - 0x365c6fff PersistentConnection armv7 &lt;81eb1b3e08cf3d7196313307ad60649d&gt; /System/Library/PrivateFrameworks/PersistentConnection.framework/PersistentConnection
0x365c7000 - 0x3670cfff CoreGraphics armv7 &lt;641fb6e558f239588a8bd05dbefff99a&gt; /System/Library/Frameworks/CoreGraphics.framework/CoreGraphics
0x36710000 - 0x367e1fff HomeSharing armv7 &lt;c336db6393593be0ae24d18d34363b35&gt; /System/Library/PrivateFrameworks/HomeSharing.framework/HomeSharing
0x367e2000 - 0x36838fff GMM armv7 &lt;5b18530ef2ab39fcb5f28da01beec3d1&gt; /System/Library/PrivateFrameworks/GMM.framework/GMM
0x36bf0000 - 0x36c9dfff EventKitUI armv7 &lt;9d7932f0583c3f0ba3352200c43f41db&gt; /System/Library/Frameworks/EventKitUI.framework/EventKitUI
0x36c9e000 - 0x36c9ffff DataMigration armv7 &lt;d067b65a904a3f438b5d9e13b208b117&gt; /System/Library/PrivateFrameworks/DataMigration.framework/DataMigration
0x36cc1000 - 0x36cc8fff IOHIDLib armv7 &lt;0a3569d241273022898b4934f672bfc2&gt; /System/Library/Extensions/IOHIDFamily.kext/PlugIns/IOHIDLib.plugin/IOHIDLib
0x36cfa000 - 0x36d2cfff MobileSoftwareUpdate armv7 &lt;dd8b230b84db33eaa7b98dea8a07f65b&gt; /System/Library/PrivateFrameworks/MobileSoftwareUpdate.framework/MobileSoftwareUpdate
0x36db2000 - 0x36db6fff Marco armv7 &lt;526949ce76323de09ee69812383c2953&gt; /System/Library/PrivateFrameworks/Marco.framework/Marco
0x36db7000 - 0x36e86fff IMGSGX535GLDriver armv7 &lt;5d2da30caa2539ffa37ba5ce9366fed8&gt; /System/Library/Extensions/IMGSGX535GLDriver.bundle/IMGSGX535GLDriver
0x36e87000 - 0x36e9dfff libdispatch.dylib armv7 &lt;defe319d1f4d3c1c8c4f18ebd96b396a&gt; /usr/lib/system/libdispatch.dylib
0x36f14000 - 0x36f14fff vecLib armv7 &lt;106ef8294b0d3c2d89e9230527846227&gt; /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/vecLib
0x36f3c000 - 0x37057fff PhotoLibrary armv7 &lt;2bd32ff1c1023d81bfbfeea2018cee9c&gt; /System/Library/PrivateFrameworks/PhotoLibrary.framework/PhotoLibrary
0x3705a000 - 0x3705efff libGFXShared.dylib armv7 &lt;0a36fb9d60a43479943bafb2f81313b1&gt; /System/Library/Frameworks/OpenGLES.framework/libGFXShared.dylib
0x3705f000 - 0x37063fff IOSurface armv7 &lt;0f003f50b18e3dbf87607d819e0ac6b9&gt; /System/Library/PrivateFrameworks/IOSurface.framework/IOSurface
0x37077000 - 0x37082fff AccountSettings armv7 &lt;090bb6a4f97433089b5cabc6a40c619a&gt; /System/Library/PrivateFrameworks/AccountSettings.framework/AccountSettings
0x370dc000 - 0x37189fff libxml2.2.dylib armv7 &lt;78462273eb5b38d1a0873b02f0e35e23&gt; /usr/lib/libxml2.2.dylib
0x3718a000 - 0x371a3fff libRIP.A.dylib armv7 &lt;ad22ea5ee99a358691f9820e62c85058&gt; /System/Library/Frameworks/CoreGraphics.framework/Resources/libRIP.A.dylib
0x371bb000 - 0x37200fff GeoServices armv7 &lt;6c9eb6372f723a57852cfc9ed7b78e31&gt; /System/Library/PrivateFrameworks/GeoServices.framework/GeoServices
0x37201000 - 0x37206fff MediaStream armv7 &lt;e744051e91ba31f9980c74d60837473d&gt; /System/Library/PrivateFrameworks/MediaStream.framework/MediaStream
0x37207000 - 0x37214fff MobileAsset armv7 &lt;67b5af6967d6332d80ff158d2aeccd1e&gt; /System/Library/PrivateFrameworks/MobileAsset.framework/MobileAsset
0x37215000 - 0x3722cfff WebBookmarks armv7 &lt;ca6cb19e568738a0a6e30b616ee33ab0&gt; /System/Library/PrivateFrameworks/WebBookmarks.framework/WebBookmarks
0x3723a000 - 0x37383fff libicucore.A.dylib armv7 &lt;1bc960f75d633190a09b093209a9f0c5&gt; /usr/lib/libicucore.A.dylib
0x373f8000 - 0x373fcfff CertUI armv7 &lt;9d24f62513913888b2ac55f1db27b908&gt; /System/Library/PrivateFrameworks/CertUI.framework/CertUI
0x37415000 - 0x374bffff libBLAS.dylib armv7 &lt;9aabff01422f3cb8960f93d11d2b6de1&gt; /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libBLAS.dylib
0x374e8000 - 0x374fdfff libresolv.9.dylib armv7 &lt;97d6ebbb53ae3e0480f51771c9665613&gt; /usr/lib/libresolv.9.dylib
0x37501000 - 0x37507fff MobileIcons armv7 &lt;2f4c13053206306996726629b0b7eb01&gt; /System/Library/PrivateFrameworks/MobileIcons.framework/MobileIcons
0x3753c000 - 0x3762afff libiconv.2.dylib armv7 &lt;6e858938edb93162ba8cf25702f08b16&gt; /usr/lib/libiconv.2.dylib
0x37634000 - 0x3763afff liblaunch.dylib armv7 &lt;09f21c3e774c30b1aab1b56c2d6efbc3&gt; /usr/lib/system/liblaunch.dylib
0x37667000 - 0x37669fff snatmap armv7 &lt;25a5f922881c3e1a86796cc7b65873a3&gt; /System/Library/PrivateFrameworks/GameKitServices.framework/Frameworks/snatmap.framework/snatmap
0x3766d000 - 0x37675fff MobileBluetooth armv7 &lt;a47ef08dc4713b28b4f5a33a7c05eb89&gt; /System/Library/PrivateFrameworks/MobileBluetooth.framework/MobileBluetooth
0x37c01000 - 0x37c10fff MultitouchSupport armv7 &lt;ef3293aa236a3dc3a3cf86621fddcdf0&gt; /System/Library/PrivateFrameworks/MultitouchSupport.framework/MultitouchSupport
0x37c17000 - 0x37c40fff AppleAccount armv7 &lt;b0baa956f6a8308a8d9faac126ef6f95&gt; /System/Library/PrivateFrameworks/AppleAccount.framework/AppleAccount
0x37c41000 - 0x37d20fff RawCamera armv7 &lt;4fb932b6a2d83c4eadfcecf53220699a&gt; /System/Library/CoreServices/RawCamera.bundle/RawCamera
0x37d52000 - 0x37d82fff ContentIndex armv7 &lt;e610e7e8c8653d728dcc3c8fb471a994&gt; /System/Library/PrivateFrameworks/ContentIndex.framework/ContentIndex
0x37d83000 - 0x37d8afff MediaRemote armv7 &lt;3deff2252a8231e7b0135a517b8391ba&gt; /System/Library/PrivateFrameworks/MediaRemote.framework/MediaRemote
0x37d8e000 - 0x37d99fff SIMToolkitUI armv7 &lt;5913d52dfeda3c2f9dd1bc1275613030&gt; /System/Library/SpringBoardPlugins/SIMToolkitUI.servicebundle/SIMToolkitUI
0x37d9a000 - 0x37db2fff TelephonyUI armv7 &lt;697ec6537ba837ae896e88c66a45c6a8&gt; /System/Library/PrivateFrameworks/TelephonyUI.framework/TelephonyUI
0x37db3000 - 0x37db3fff Accelerate armv7 &lt;a62771c826753815a5cae96eaa60ffd7&gt; /System/Library/Frameworks/Accelerate.framework/Accelerate
0x37dce000 - 0x37e17fff AddressBook armv7 &lt;0a858565acd03f28a1bc69a650b64a7b&gt; /System/Library/Frameworks/AddressBook.framework/AddressBook
0x37e97000 - 0x37efbfff MessageUI armv7 &lt;c9d526c181ed3625b32327044d78dad3&gt; /System/Library/Frameworks/MessageUI.framework/MessageUI
</string>
<key>displayName</key>
<string>SpringBoard</string>
<key>name</key>
<key>os_version</key>
<string>iPhone OS 5.0.1 (9A405)</string>
<key>system_ID</key>
<string></string>
<key>version</key>
<string>??? (???)</string>
<key>blame</key><array>
<array><string>/System/Library/BulletinBoardPlugins/MailDataProvider.bundle/MailDataProvider</string><integer>-2147483578</integer></array>
</array>
</dict>
</plist>
S
Sean71596
Michigan
And Now For the Syslog. Not sure If you can do anything with these, but hey; worth a try if you know what this means...
## syslog
Dec 15 09:37:00 Seans-iPad-of-Awesomeness SpringBoard[168]: -[SBApplication displaySetting:]: unrecognized selector sent to instance 0x347a20
Dec 15 09:37:00 Seans-iPad-of-Awesomeness SpringBoard[168]: *** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '-[SBApplication displaySetting:]: unrecognized selector sent to instance 0x347a20'
Dec 15 09:37:00 Seans-iPad-of-Awesomeness com.apple.SpringBoard[168]: terminate called throwing an exception
Dec 15 09:37:00 Seans-iPad-of-Awesomeness ReportCrash[181]: Formulating crash report for process SpringBoard[168]
Dec 15 09:37:00 Seans-iPad-of-Awesomeness softwareupdateservicesd[180]: MS:Notice: Loading: /Library/MobileSubstrate/DynamicLibraries/Backgrounder.dylib
Dec 15 09:37:00 Seans-iPad-of-Awesomeness softwareupdateservicesd[180]: MS:Warning: message not found [UIApplication _loadMainNibFile]
Dec 15 09:37:00 Seans-iPad-of-Awesomeness softwareupdateservicesd[180]: MS:Notice: Loading: /Library/MobileSubstrate/DynamicLibraries/BackwardCompatibility.dylib
Dec 15 09:37:01 Seans-iPad-of-Awesomeness softwareupdateservicesd[180]: MS:Notice: Loading: /Library/MobileSubstrate/DynamicLibraries/RotationInhibitor.dylib
Dec 15 09:37:01 Seans-iPad-of-Awesomeness com.apple.launchd[1] (com.apple.SpringBoard[168]): (com.apple.SpringBoard) Job appears to have crashed: Abort trap: 6
Dec 15 09:37:01 Seans-iPad-of-Awesomeness UIKitApplication:com.apple.mobilemail[0x5e3a][179]: Terminating in response to SpringBoard's termination.
Dec 15 09:37:01 Seans-iPad-of-Awesomeness SpringBoard[182]: MS:Notice: Installing: com.apple.springboard [SpringBoard] (675.00)
Dec 15 09:37:01 Seans-iPad-of-Awesomeness SpringBoard[182]: MS:Warning: Entering Safe Mode
Dec 15 09:37:01 Seans-iPad-of-Awesomeness SpringBoard[182]: MS:Error: Cannot Stack: Cannot allocate memory
Dec 15 09:37:01 Seans-iPad-of-Awesomeness SpringBoard[182]: MS:Notice: Loading: /Library/MobileSubstrate/DynamicLibraries/MobileSafety.dylib
Dec 15 09:37:01 Seans-iPad-of-Awesomeness SpringBoard[182]: MS:Warning: nil class argument
Dec 15 09:37:01: --- last message repeated 2 times ---
Dec 15 09:37:01 Seans-iPad-of-Awesomeness SpringBoard[182]: MS:Warning: message not found [UIImage defaultDesktopImage]
Dec 15 09:37:01 Seans-iPad-of-Awesomeness softwareupdateservicesd[180]: MS:Notice: Loading: /Library/MobileSubstrate/DynamicLibraries/WinterBoard.dylib
Dec 15 09:37:01 Seans-iPad-of-Awesomeness softwareupdateservicesd[180]: MS:Warning: nil class argument
Dec 15 09:37:01 Seans-iPad-of-Awesomeness ReportCrash[181]: Saved crashreport to /var/mobile/Library/Logs/CrashReporter/SpringBoard_2011-12-15-093700_Seans-iPad-of-Awesomeness.plist using uid: 0 gid: 0, synthetic_euid: 501 egid: 0
Dec 15 09:37:01 Seans-iPad-of-Awesomeness kernel[0]: virtual void AppleRGBOUT::do_power_state_change(): fSoft: 1 fHard: 1 swapBusy: 0 fController: 0 -> 1
Dec 15 09:37:01 Seans-iPad-of-Awesomeness kernel[0]: bool AppleRGBOUT::power_up_hardware()
Dec 15 09:37:01 Seans-iPad-of-Awesomeness kernel[0]: set_crc_notification_state 0
Dec 15 09:37:01 Seans-iPad-of-Awesomeness kernel[0]: virtual void AppleRGBOUT::do_power_state_change(): fSoft: 0 fHard: 1 swapBusy: 0 fController: 1 -> 0
Dec 15 09:37:01 Seans-iPad-of-Awesomeness kernel[0]: bool AppleRGBOUT::power_down_hardware()
Dec 15 09:37:01 Seans-iPad-of-Awesomeness kernel[0]: bool AppleRGBOUT::power_down_hardware(), clock down RGBOUT
Dec 15 09:37:01 Seans-iPad-of-Awesomeness kernel[0]: bool AppleRGBOUT::power_down_hardware(), RGB_CTRL (0x00000000) clk_down_ready is not set after 60 msecs
Dec 15 09:37:01 Seans-iPad-of-Awesomeness kernel[0]: IOReturn AppleRGBOUT::set_display_device_gated(uint32_t), 1
Dec 15 09:37:01 Seans-iPad-of-Awesomeness kernel[0]: virtual void AppleRGBOUT::do_power_state_change(): fSoft: 1 fHard: 1 swapBusy: 1 fController: 0 -> 1
Dec 15 09:37:01 Seans-iPad-of-Awesomeness kernel[0]: IOReturn IOMobileFramebufferUserClient::set_hotplug_notify(void*, void*) 0x31b13c31 0x10237600
Dec 15 09:37:01 Seans-iPad-of-Awesomeness kernel[0]: IOReturn IOMobileFramebufferUserClient::set_hotplug_notify(void*, void*) 0x86fd9200 0x8aff73a0 0x31b13c31 0x10237600
Dec 15 09:37:01 Seans-iPad-of-Awesomeness softwareupdateservicesd[180]: MS:Warning: message not found [UIImage defaultDesktopImage]
Dec 15 09:37:01: --- last message repeated 19 times ---
Dec 15 09:37:01 Seans-iPad-of-Awesomeness softwareupdateservicesd[180]: MS:Notice: Loading: /Library/MobileSubstrate/DynamicLibraries/libstatusbar.dylib
Dec 15 09:37:01 Seans-iPad-of-Awesomeness softwareupdateservicesd[180]: MS:Notice: Loading: /Library/MobileSubstrate/DynamicLibraries/sandcastleclient.dylib
Dec 15 09:37:01 Seans-iPad-of-Awesomeness SpringBoard[182]: No AppleBaseband service detected. Cellular data disabled.
Dec 15 09:37:01 Seans-iPad-of-Awesomeness SpringBoard[182]: WiFi: Consulting "no-sdio-devices" property.
Dec 15 09:37:01 Seans-iPad-of-Awesomeness SpringBoard[182]: WiFi: "no-sdio-devices" property not found.
Dec 15 09:37:01 Seans-iPad-of-Awesomeness SpringBoard[182]: lockdown says the device is: [Activated], state is 3
Dec 15 09:37:01 Seans-iPad-of-Awesomeness SpringBoard[182]: Posting 'com.apple.iokit.hid.displayStatus' notifyState=1
Dec 15 09:37:01 Seans-iPad-of-Awesomeness SpringBoard[182]: __IOHIDLoadBundles: Loaded 1 HID plugin
Dec 15 09:37:02 Seans-iPad-of-Awesomeness SpringBoard[182]: CLTM: initial thermal level is 0
Dec 15 09:37:02 Seans-iPad-of-Awesomeness SpringBoard[182]: MultitouchHID: detection mode: 255->0 (deferring until bootloaded)
Dec 15 09:37:02 Seans-iPad-of-Awesomeness locationd[47]: hidd died. Reestablishing connection.
Dec 15 09:37:02 Seans-iPad-of-Awesomeness kernel[0]: bool AppleRGBOUT::power_down_hardware()
Dec 15 09:37:02 Seans-iPad-of-Awesomeness kernel[0]: bool AppleRGBOUT::power_down_hardware(), clock down RGBOUT
Dec 15 09:37:02 Seans-iPad-of-Awesomeness kernel[0]: bool AppleRGBOUT::power_down_hardware(), RGB_CTRL (0x00000000) clk_down_ready is not set after 60 msecs
Dec 15 09:37:02 Seans-iPad-of-Awesomeness SpringBoard[182]: BTM: attaching to BTServer
Dec 15 09:37:03 Seans-iPad-of-Awesomeness SpringBoard[182]: Reply Error: Connection invalid
Dec 15 09:37:03 Seans-iPad-of-Awesomeness SpringBoard[182]: spd:_libspd_initialize_protocol:142 Registered notification port with spd [PID=177]
Dec 15 09:37:03 Seans-iPad-of-Awesomeness SpringBoard[182]: spd:_libspd_initialize_notify:241 All set up for spd wake notifications
Dec 15 09:37:04 Seans-iPad-of-Awesomeness SpringBoard[182]: BTM: posting notification BluetoothAvailabilityChangedNotification
Dec 15 09:37:04 Seans-iPad-of-Awesomeness SpringBoard[182]: BT: BTLocalDeviceGetConnectable returned error 111
Dec 15 09:37:04 Seans-iPad-of-Awesomeness SpringBoard[182]: BTM: BTLocalDeviceGetPairedDevices returned 0 devices
Dec 15 09:37:04 Seans-iPad-of-Awesomeness SpringBoard[182]: WiFi: Consulting "no-sdio-devices" property.
Dec 15 09:37:04 Seans-iPad-of-Awesomeness SpringBoard[182]: WiFi: "no-sdio-devices" property not found.
Dec 15 09:37:04 Seans-iPad-of-Awesomeness kernel[0]: Sandbox: ignoring builtin profile for platform app: /private/var/stash/Applications.jseLxi/MobileMail.app/MobileMail
Dec 15 09:37:04 Seans-iPad-of-Awesomeness SpringBoard[182]: EKAlarmEngine: Region monitoring not available or enabled. Trigger ignored!
Dec 15 09:37:04 Seans-iPad-of-Awesomeness SpringBoard[182]: SMS Plugin initialized.
Dec 15 09:37:05 Seans-iPad-of-Awesomeness SpringBoard[182]: SIMToolkit plugin for SpringBoard initialized.
Dec 15 09:37:05 Seans-iPad-of-Awesomeness SpringBoard[182]: WiFi: Consulting "no-sdio-devices" property.
Dec 15 09:37:05 Seans-iPad-of-Awesomeness SpringBoard[182]: WiFi: "no-sdio-devices" property not found.
Dec 15 09:37:05 Seans-iPad-of-Awesomeness SpringBoard[182]: WiFi picker plugin initialized
Dec 15 09:37:05 Seans-iPad-of-Awesomeness kernel[0]: AppleKeyStore:timer fired
Dec 15 09:37:05 Seans-iPad-of-Awesomeness kernel[0]: AppleKeyStore:cp_key_store_action(0)
Dec 15 09:37:05 Seans-iPad-of-Awesomeness kernel[0]: AppleKeyStore:Removing timer
Dec 15 09:37:05 Seans-iPad-of-Awesomeness kernel[0]: AppleKeyStore:Sending lock change
Dec 15 09:37:05 Seans-iPad-of-Awesomeness SpringBoard[182]: [Warning] The RowID is out of bounds. We were asked for rows after [0] which exceeds the current sequence number [-1]
Dec 15 09:37:13 Seans-iPad-of-Awesomeness timed[174]: (Note ) CoreTime: Not setting system time to 12/15/2011 14:37:13 from NTP because time is unchanged
Dec 15 09:37:13 Seans-iPad-of-Awesomeness timed[174]: (Note ) CoreTime: Not setting time zone to America/Detroit from Location
Dec 15 09:37:23 Seans-iPad-of-Awesomeness SpringBoard[182]: spd:___libspd_initialize_protocol_block_invoke_2:172 spd [PID=177] went bye-bye
Dec 15 09:37:32 Seans-iPad-of-Awesomeness profiled[19]: (Note ) profiled: Device unlock notification received
Dec 15 09:37:32 Seans-iPad-of-Awesomeness kernel[0]: AppleKeyStore:cp_key_store_action(1)
Dec 15 09:37:32 Seans-iPad-of-Awesomeness kernel[0]: AppleKeyStore:Sending lock change
Dec 15 09:37:49 Seans-iPad-of-Awesomeness com.apple.networkd[187]: main:212 networkd.187 built Nov 2 2011 20:21:54
Mickey330
Western NY state (USA)
Whoa! You've just moved way out of my range! I'm not a programmer, just a user. Sorry, but that code is sheer gibberish to me. :eek:
Which made me wonder - why haven't the other jailbreakers chimed in. And, wouldn't you know it! This post isn't in the Hacking section. Well, it wasn't, cause I've just moved it over there (here?).
Maybe a more experienced jail breaker/coder can help. Cause I am w-a-y lost and out of my league here.
I still suggest you just go for the manual re-install of the Cydia stuff. But, that's just me and YMMV...
Good luck.
graywolf
Raleigh, NC USA
Sounds like you installed and app that is only iPhone compatible.
And based on your crash log, have you been deleting anything? According to the log, many things are missing, such as splash screens and some core UI elements.
Edit:
I also see you have Backgrounder installed and it is crashing. The last version that backgrounder was compatible with was like 4.2.2.
I think the problem is Backwards Compatibility. It's made for iPhone on 2.0.
S
Sean71596
Michigan
Yes I did delete a dew things, trying to fix the problem. Nothing essential though. Found out the problem after a backup/restore today. It's the cydiapp "Backgrounder". It might not be the only problem child, but when i reninstalled all of my cydiapps in alphabetical order, I ran into a problem in the 'B' apps. Theres only 3, and deleting it fixed it (so far; still installing apps). I will let you know if there's any other problems. You should probably repost this- DO NOT INSTALL EITHER​ VERSION OF BACKGROUNDER ON IPAD.
graywolf
Raleigh, NC USA
Yep. I knew it was backgrounder. :)
