Having problem with podcast screen black and cant return tonormal screen
yowee
I all
Found out today that a podcast I downloaded made the screen go black and I have no controls (I think)
Get back to main screen but not the video
Have powered it off and still no good
Please help
Adrian
leelai
Brisbane, Australia
Hi and welcome to the Forum!
When an app behaves strangely it is best to close it completely and then relaunch it. From the home screen do the four finger swipe up or double press the home button to reveal your multi task bar. These are all the apps that you have opened at one time. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it, now press the home button to return to your screen. It's also a good idea to close all these apps, as it helps the iPad run smoothly. Let us know how you go.
iPad 2 3G 64gb
yowee
yowee
Thanks for the information and I followed you instruction. The app did the same thing opened up with a screen that seems to be larger than the screen.
Still not able to shut down the podcast. It may not be the podcast as the the video program has not started and is not shown
