Had or having IPad 2 wifi connection problems?
Discussion in 'Apple iPad Polls' started by drb_52, Aug 7, 2011.
Had or having wifi connection problems?
  1. Ipad 2 - 16 GB Wifi only
    27.3%
  2. Ipad 2 - 32 GB Wifi only
    45.5%
  3. Ipad 2 - 64 GB Wifi only
    9.1%
  4. Ipad 2 - 16 GB Wifi + 3g ATT
    0 vote(s)
    0.0%
  5. Ipad 2 - 32 GB Wifi + 3g ATT
    9.1%
  6. Ipad 2 - 64 GB Wifi + 3g ATT
    9.1%
  7. Ipad 2 - 16 GB Wifi + 3g Verizon
    0 vote(s)
    0.0%
  8. Ipad 2 - 32 GB Wifi + 3g Verizon
    0 vote(s)
    0.0%
  9. Ipad 2 - 64 GB Wifi + 3g Verizon
    0 vote(s)
    0.0%
  1. drb_52
    drb_52
    May 19, 2011
    184
    5
    Identify your iPad model in the poll. Post the router manufacturer and model that you are unable to connect or maintain the connection.
    If you have solved your problem, post how you did it if you know. Provide details if you can, but don't speculate. As Joe Friday use to say, "Just the facts".
    Who knows, maybe a common issue will surface.
    If you have not had a problem, please do not vote.
    #1 drb_52, Aug 7, 2011
  2. macaudiocompany
    macaudiocompany
    Aug 7, 2011
    No problems my side.
  3. iforsakenu
    iforsakenu
    Jun 12, 2011
    128
    64GB 3G AT&T
    Cisco Valet Plus Router
    Yes, sometimes I drop signal for no reason, and have to reboot my ad or home network. Figured apple would realize aluminum doesn't mesh well with connectivity between different devices.
  4. col.bris
    col.bris
    Staff Member
    Mar 25, 2010
    5,883
    691
    Routers are the main problem not the device prior to having my BIGPOND cable modem router replaced I had issues now fine in addition I have had no problems on either a iPad 1 or iPad 2 at many locations including corporate networks. The only time I had an issue was at a friends home as he had a old router which again has been replaced and works fine now.
  5. beesy
    beesy
    Apr 20, 2011
    17
    Ipad 2 wifi 64 GB
    I have had absolutley NO Problems with my ipad, it is GREAT GREAT GREAT, android or any other tablet cannot compare with the ipad 2. What else can I say ....I have the HTC Incredible phone, and have had trouble with memory and other stuff. but my Ipad is the best investment I have made ...i LOVE IT!!! One more thing, don't get 3g, wifi is all you need, but do get the 64gb because you will want to put alot of great apps, games, music and books on it. A FINE MACHIN INDEED!:)
  6. jbcheshire
    jbcheshire
    Apr 19, 2011
    7
    Yes, I have wifi problems off and on with my DLink Dir-655 router. But, I have 2 iPad 1's @ 16gb & 32gb wi-fi only.. However, I think the problem may be my router auto-switching channels. I turned that off and selected a higher channel as permanent and haven't seen any wi-fi drops in the past few days...
  7. magsmag
    magsmag
    Aug 9, 2011
    32
    I have connection problems all the time at home with wifi......but so do the laptops in the house. I switch to 3g but thst doesn 't work either.....it works outside though.
  8. beesy
    beesy
    Apr 20, 2011
    17
    you should have a space for no problems
    My 64gb wifi only is the best machine ever, If you could love a machine, then I do!!! Outstanding product. Go Apple. I have an htc incredible phone, and have had nothing but problems..... When My contract is up with verizon I will switch to Iphone. One more thing, AT&T suck the big one!!!! verizon, tmobile and sprint rock.:)
  9. beesy
    beesy
    Apr 20, 2011
    17
    This poll is stupid
  10. giokspy
    giokspy
    Jul 25, 2011
    30
    No strong signal but never problems. iPad 2 wifi 16Gb
aigo pad have connection problem
ipad 2 connection problems
ipad 2 connectivity sucks
ipad 2 having trouble connecting to wifi
ipad 2 wifi connectivity issues
ipad2 connectivity issues wifi
ipad2 wifi sucks
unable to connect ipad2 to wireless network
verizon ipad 2 wifi problems
why does my ipad 2 wifi suck
