Forum Help and Questions
Discussion in 'Forum Rules, Help and Info' started by Max, Apr 21, 2010.
  1. dianne137
    dianne137
    Jan 27, 2013
    633
    89
    right I get the rules I just don't know how to copy a web add. In blue so that a thread reader could easily open it .thanks
  2. blackbj100
    blackbj100
    Sep 1, 2013
    First visit here. Reads well so far. Thanks
  3. mgmeredith
    mgmeredith
    May 8, 2014
    i misspelled my user id that i wanted to use. can i change it? thanks
  4. JohnnyApple
    JohnnyApple
    Staff Member
    Jan 17, 2010
    841
    106
    Send me a PM with the username you want, I'll update it.
  5. Troglodyte96
    Troglodyte96
    iPad Addict
    Feb 3, 2013
    1,415
    9
    Ok I give up, where have you hidden the signature settings? I'm sure I've just missed it somewhere. Been using the app for ages and knew my way around that fairly well, but I can't find any way of editing or creating a signature here. My old signature still shows up in my profile, but not my posts, presumably because I disabled it when I started using the app.
    Someone please help, it's driving me nuts.
    #315 Troglodyte96, Jun 20, 2014
  6. J. A.
    J. A.
    Staff Member
    Nov 11, 2012
    21,359
    14,194
    When you go to the top of the website, you'll find your user name and avatar. Tap it, and a popup will appear. There you'll find "Signature". Select it to edit the signature.
    • Informative Informative x 1
    • List
  7. Troglodyte96
    Troglodyte96
    iPad Addict
    Feb 3, 2013
    1,415
    9
    Thanks so much, can't believe I missed it.
  8. J. A.
    J. A.
    Staff Member
    Nov 11, 2012
    21,359
    14,194
    Glad to help. I like your signature. :D
  9. errolgreer
    errolgreer
    Dec 15, 2016
    8
    In the Forums section showing new posts, I would like to start a post but cannot see any icon to start the new post
  10. twerppoet
    iPad Legend II
    Jan 8, 2011
    21,638
    8,257
    You must select the forum area you are going to post to before you see a Post New Thread button. Becaues the New Posts screen shows threads from multible areas, it does not have a New Post Thread button.
    Note: The following screenshots may not look like your screen. I’ve set the forum to show me an older style/coler UI. However, they should be similar enough that you can figure out what to do from them
    To see the list of forum areas, tap the Forum menu item (even if it is already highlighted).
    Once you’ve selected an area you should see the Post New Thread button.
    Also notice the path list just below the main and secondary menu. You can use this to move backwards to the forum area when in a thread.
    The name of the thread or fourum area is just above the list of threads or posts.
audio icon won't go away ipad2
content
ipad2 speaker icon won't go away
ipad4 icons meaning
