Flickr Problems
BrianMc
is anyone else having problems with uploading pictures from an iPad2 using iPhoto I just cannot get it to work despite have deleted the app and then reloaded it. The upload freezes every time.
Any help would be greatly appreciated.
Milton-Freewater, OR
Try the usual, if you have not done so. Also, be sure you have a good internet connection.
