FaceTime and IMessage problem
Discussion in 'iPad 2 Forum' started by Kusadasi08, May 22, 2012.
  1. Kusadasi08
    Kusadasi08
    Jan 30, 2012
    My wife is on holiday in Turkey and I am in the Uk, we can talk to each other on Skype, but cannot get FaceTime or I message to work, trying to contact her from the uk it just seems to ring and ring and ring. When trying to contact me from Turkey she just gets the message FaceTime failed after a couple of rings. Is there something I have missed in setting up these Ipad 2 s ? Can't work out why Skype works but FaceTime or I message does not. any help greatly appreciated.
  2. KevinJS
    KevinJS
    Staff Member
    Aug 6, 2011
    10,634
    1,388
    Are you both on wifi? FaceTime doesn't work on 3G.
    Also, you need to delete the AppleID email address from FaceTime in Settings on one of the iPads and replace it with another.
    Sent from my iPad 4 HD mini
  3. KevinJS
    KevinJS
    Staff Member
    Aug 6, 2011
    10,634
    1,388
    Same deal for iMessage. You need to change the "receive at" email address.
  4. Kusadasi08
    Kusadasi08
    Jan 30, 2012
    Thanks for that, will have a look, but they worked when both in the UK, have had a friend try to contact using FaceTime with their iPad 3 to no avail. thanks for your help.
does face time work in turkey
does facetime work in turkey
facetime failed
facetime failed message
facetime failed on ipad 2
facetime failed on ipad 3
facetime in turkey
facetime wont work in turkey
ipad facetime failed message
turkey facetime
