Facebook Problem
Steve2150
When I try to comment on a thread in facebook it lets me type but there is no send or post button, pushing return does nothing but move line down. If I post a new thread there is a post or share button, any ideas.
Milton-Freewater, OR
It is a known problem.
The send button only shows if you are using the touch keyboard in docked (not split) mode. That goes for no bluetooth keyboard too, though it you tap the eject key to pop up the touch keyboard (not split) you should see the send button.
Madchiller
New York
So I am having the same problem, but I am not using a wireless keyboard or split keyboard. Furthermore I cannot even see what I am typing! :(. Any ideas?
Sent from my iPad 2 using iPF
Just the usual.
Clear: With the problem app closed, double tap on the Home button to get the multitask bar. Tap and hold on any icon in the bar until they jiggle, then tap the minus sign on the problem app. This will remove it from RAM and insure a clean start the next time you launch the app.
You can also try deleting the app off the iPad and re-installing it.
Madchiller
New York
Thanks for your help. Had already tried of all that before posting. I even tried removing black keyboard from cydia. Removed the original Facebook activator, that was used to get the ipad version, before the official iPad app was released. I feel it's something in cydia. Maybe fullforce or something? I don't have much installed from cydia. Hhhmmmmm.
Ah, well I'm afraid my experience is limited to the stock iPad. :eek:
You might try searching the Hacking forum to see if anyone has reported a similar problem.
Madchiller
New York
Fixed!!!!!! :). It was Fullforce. Full force was maximizing the Facebook app in such a way it's was messing it up. Removed it In Cydia and it work perfectly now.
Madchiller
New York
Yeah. You know. Trying to make every app use the maximum amount of screen space! ;). Unfortunately the facebook app uses many sub windows, and I think full force was trying to affect these as well. Funny thing is I swear i didn't even have the Facebook app selected in full force. Very strange.
Hayles66
Somerset-UK
Well, you learn something every day!
Ok, then I'm guessing Full Force is meant to be used with iPhone apps, yes? That would make sense.
Thanks.
Madchiller
New York
Yes sir! I guess I will have to get retina pad and see how it goes with that.
