Face time on Ipad2....Network Connection problems....
Discussion in 'iPad 2 Forum' started by MYIpad2, Apr 23, 2011.
  1. MYIpad2
    MYIpad2
    Apr 23, 2011
    I wonder if you may be able to help me with this. I just purchased the Ipad2 and when it comes to setting up face time I am getting the message of "could not sign in. please check your network activation..." I know my network is set up correctly as i am able to surf the web and download apps. I know my email address is verified and works with facetime on my mac and my iphone, but for some reason I can not complete activation on my ipad2....
    this is really frustrating...any thoughts?
    thanks:confused:
  2. Fakhry
    Fakhry
    Apr 19, 2011
    19
    i think thats a bug of ios 4.3 . maybe you must upgrading to the last version 4.3.2 . because this version contains bug fixes for face time and trouble connection issues
  3. gortyargen
    gortyargen
    Apr 24, 2011
    I had the same problem. Try this it worked for me.Go to Settings - WiFi Press the > at the side of your wifi connection Change the DNS numbers to 8.8.8.8 Never any problems for me after that
  4. JJK
    JJK
    Apr 11, 2011
    389
    7
    You can also try resetting your network settings. That seems to have the trick with me.
  5. svarup
    svarup
    Apr 21, 2011
    8
    This finally did the trick for me too! I did not create a new account, just changed the DNS to 8.8.8.8
    Thank you very much for sharing!
  6. Kenwaja
    Kenwaja
    Apr 30, 2011
    Same error msg after change dns to 8.8.8.8
    should I update to iOS 4.3.2.....now is with iOS 4.3.1
  7. Liberlike
    Liberlike
    Apr 30, 2011
    7
    DNS change
    Sorry, DNS change didn't work for me...
  8. jackitec
    jackitec
    May 11, 2012
    5
    Hello all, i have problems with face time freezing on my ipad2, i have the latest software installed and i have changed dns numbers to a few different ones still the same, does anyone know how much bandwidth FaceTime uses, I have a 2meg wifi connection,
    Regards,
    Jack.
check your internet connection for i-pad 2 for face time help
facetime check network connection
facetime connection problems
facetime connection problems ipad 2
facetime ipad network connection problem
how to set up network connections to face time
network activication for ipad problem
network connection for face time on ipad with upgrade 7
trouble shoot face time om i pad
tutorial to troubleshoot face how to change the time on my ipad
