Dropbox problems
buzzy23
florada
I have been having some trouble with Dropbox. I have it installed on my pc and my iPad. Up till now it has been working pretty well. But today it would no longer send files to my iPad. It uploads the files to the dropbox home page but not send to my pc. My pc is using XP and my ipad2 is using iOS 4.3.3
Can someone help?
Regards buzzy23
Tim SPRACKLEN
