Does iPad consume battery when hibernated?
Discussion in 'iPad General Discussions' started by mobi1, Apr 13, 2011.
  1. mobi1
    mobi1
    Apr 6, 2011
    239
    If I just press on/off switch once it goes to sleep mode and wakes up instantly when I press it again.
    Does it consume battery during this time? I understand to run system clock etc. some power will be consumed but how does it compare with fully switching the unit off?
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    In addition, some tasks and hardware can be running when the iPad is in Sleep mode - for example the WiFi and 3G are switched on and the iPad can be programmed to check for email every so often, even when it's in sleep.
    Have a look here for the official line on extending your iPad's battery life
    Apple - Batteries - iPad
  3. DontUnderstandMyIpad
    iPad Guru
    Jan 22, 2011
    3,192
    13
    Yes, the device still consumes battery, mostly for apps connecting to the Internet, such as checking for mails. But the most battery is used for powering the display, so as long as that is off, will the device rarely use any battery.
does ipad use battery in sleep mode
does ipad use battery sleep mode
does ipad use battery when asleep
does ipad use battery when in sleep mode
does sleep mode use battery life on nipad
does sleep mode use battery on ipad
ipad battery hibernate
ipad battery life when hibernating
ipad battery use in sleep mode
sleep mode does the ipad usebattery
