Do i have a problem?
Discussion in 'iPad Help' started by barbieb12, Apr 9, 2012.
  1. barbieb12
    barbieb12
    Sep 1, 2011
    25
    I recently noticed when my I pad is checking for mail, after it up dates then it says sending 6 unsent messages. Why is this happening and how do I stop it? There is no mail to be sent!
  2. Gabriel1
    Gabriel1
    iPad Legend
    Mar 11, 2011
    17,091
    747
    Hi and welcome,
    I've just moved this to the help section to get a better chance for an answer for you.
  3. twerppoet
    iPad Legend II
    Jan 8, 2011
    21,953
    8,856
    Apparently the iPad has failed to send some email at some point. If you have some emails that fail to send for one reason or another the iPad will try again each time the Mail app is opened.
    You can see what these emails are (if you are fast enough, or then fail again). Tap the Mailbox button at the top of the email list until you see a list of Inboxes and Accounts. If there is pending/outgoing email there will also be an Outbox. This only shows up when there is outgoing email on the iPad that has failed, or is still in the process of being sent.
    Open the Outbox (if visible) and look at what's in it. That may explain things, or not.
  4. barbieb12
    barbieb12
    Sep 1, 2011
    25
    Thank you so much, problem solved! You are a genius, this was driving me nutso!!
  5. twerppoet
    iPad Legend II
    Jan 8, 2011
    21,953
    8,856
    No problem. Glad it was helpful.
delete unsent messages ipad
how to delete unsent messages on ipad
how to you retrieve an unsent message on apple ipad
i have unsent messages on my ipad
ipad 2 unsent messages
ipad has unsent messages
ipad retrieve unsent email
on the ipad why would it say unsent messages
why do i have unsent messages on my ipad
