Display problem
Oldbones
My iPad thinks it should be about 1cm bigger all around!!! For the past week the display is not fitting in the physical space of the screen. I can move it to look at all bits but I cannot get it to stay the correct size. Help
Mjj455
NYC
Had the same problem once. Try this...double tap the screen with three fingers. It worked for me.
Udaiveer
India
Mjj455 is totally correct, u double tab with 3 finger Kindda zoomed in, n u can PAN/move around by draging 2 fingers. (can Disable it) somewher in UNIVERALL ACCESS
pref.
