Dark or light background for better battery life?
Discussion in 'iPad 2 Forum' started by Mountainbikermark, Apr 19, 2011.
  1. Mountainbikermark
    Mountainbikermark
    iPad Addict
    Mar 10, 2011
    1,392
    6
    I know the iPad gets very good battery life but I do a lot of reading and am wondering if the iPad gets better battery life with the light or dark background. I keep my brightness all the way down on either except when I go outside.
    On my Incredible with AMOLED display the blacker the background the better the battery life on a very noticeable level and it's easier to read with a dark background.
    I am wondering which background is better for battery life,if either, as either is comfortable to use.
    Thank you.
    Support Our Troops!
    This post was Tapatalk approved
    Sent from my iPad
  2. Gunny008
    Gunny008
    Nov 7, 2010
    362
    I never thought a dark or light background would affect the battery? only the brightness level?
  3. Jman09
    Jman09
    May 6, 2010
    194
    I don't think the screen color matters with the iPad. As with your Incredible has a different type of screen "AMOLED" which can save battery power with a dark background.
  4. Mountainbikermark
    Mountainbikermark
    iPad Addict
    Mar 10, 2011
    1,392
    6
    Thank you. I know the Ipad isn't AMOLED and am not sure if it would be considered LCD, which prefers white is why I asked.
    Thank you again.
    Support Our Troops!!
    This post was Tapatalk approved. Sent from my Incpad
  5. USBill
    USBill
    Apr 29, 2010
    399
    Unless the pixels are off, they're powered, so you probably won't see any significant difference in battery life because of the wallpaper.
    Keep the screen on low when you can and you'll be fine.
  6. madhatter61
    madhatter61
    Mar 7, 2011
    374
    The technical side of iPad2 is identical. The only difference is the color of the bezel.
    Specs from Apple.
    9.7-inch (diagonal) LED-backlit glossy widescreen Multi-Touch display with IPS technology
    1024-by-768-pixel resolution at 132 pixels per inch (ppi)
    Fingerprint-resistant oleophobic coating
    AMOLED has nothing to do with Apple products at this time.
    #6 madhatter61, Apr 20, 2011
  7. Mountainbikermark
    Mountainbikermark
    iPad Addict
    Mar 10, 2011
    1,392
    6
    That's why I asked.I knew my Ipad isn't AMOLED. Ipad is lEd? Good to know for trying to view with sunglasses on. Skip my polarized Oakleys
    Thank you
black iphone wallpaper saves battery
black wallpaper save battery ipad
dark wallpaper iphone save battery
does white on black save ipad battery
ipad dark background or light background
iphone battery dark backgrounds
is dark or light back ground better
wallpaper that saves battery ipad
whats better light or dark background
white wallpaper iphone save battery
