Customizing Maps Help please
Discussion in 'iPad Apps' started by C.J., Jun 24, 2011.
  1. C.J.
    C.J.
    Jun 23, 2011
    18
    Ok im not sure if I would use google earth, bing maps (favorite), or the maps app but I am trying to add different colored property lines and locations to a hybrid/satellite type map on my Ipad. Anyone know how to do this? I need it to save the locations and lines to look at again later.
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,236
    122
    A workaround is to take a screen shot of the map image that you want to see later. You can then view this in the Photos app and use third-party apps to annotate and edit it.
  3. C.J.
    C.J.
    Jun 23, 2011
    18
    are there not any apps that have maps in them for you to do this with?
  4. C.J.
    C.J.
    Jun 23, 2011
    18
    you can customize google earth to make custom maps
