Constant Wireless Issues
Discussion in 'iPad General Discussions' started by dminches, Jul 5, 2010.
  1. dminches
    dminches
    Jun 5, 2010
    12
    I am very frustrated by the frequent wireless signal drops I am experiencing. I cannot maintain a constant signal via wireless for more than 15 minures. I do not have the same issues with 3G nor with other computers getting a signal from my access point. I am no more than 15 feet away with a clear line to the access point.
    Has anyone figured out any iPad or router tweaks to improve this? I have turned off auto brightness but that didn't help.
  2. chandar
    chandar
    Jun 29, 2010
    27
    I am also facing frequent wireless disconnection issues. My Sony Vaio laptop does not have any problems when used in the same place.
    A suggestion I read elsewhere is to hold the ipad vertically! (obviously inspired by iphone4 issues!)
    Try holding it differently and see if you come up with some improvement!
  3. iVan
    iVan
    iPad Ninja
    Feb 19, 2010
    1,929
    7
    I'm having similar issues too. The iPad is asking for my wireless network's password every hour or so and the dang thing has 28 characters. I just copy and paste from the note tablet but it's a hasle I could live without. Sometimes I just turn off wifi and turn it back on and that works but still...
    My service provider prefers that I not change router since it's theirs.
    Wasn't a fix on the way from Apple?
  4. dminches
    dminches
    Jun 5, 2010
    12
    I am usually not even holding it since I have a nice case which holds the iPad at an angle. There is clearly an issue with the wireless connectivity. Hopefully it will get fixed.
  5. Dr.Gee
    Dr.Gee
    May 3, 2010
    408
    try a router firmware update.Probably not the problem,but i have cleared up device specific problems by doing this.
    #5 Dr.Gee, Jul 5, 2010
  6. dminches
    dminches
    Jun 5, 2010
    12
    That is apple's response and I don't buy it. I have no issues with either my laptop or my wireless music streamer. The issue isn't the router. It is the iPad.
  7. Dr.Gee
    Dr.Gee
    May 3, 2010
    408
    as my edit states,it cleared up a device specific problem.i.e. I had one netbook that kept dropping.The firmware update resolved it. All other devices were connecting fine. Worth trying I guess.
  8. figmo10
    figmo10
    Apr 15, 2010
    517
    Unless I turn off wifi, I can't keep my iPad from connecting with my neighbor's unsecured network. They're about 200 ft. from my door.
  9. Dr.Gee
    Dr.Gee
    May 3, 2010
    408
    doesnt "forget network" in settings resolve this?
  10. figmo10
    figmo10
    Apr 15, 2010
    517
    No.
ipad can't connect to tp link wireless
ipad sucks with wifi dropout
ipad wifi connection sjcks
ipad wifi issues tplink
problems connecting ipad air to tp link
tp link connection problem with apple ipad
tp link ipad
tp-link and ipad
tplink ipad
wifi connection sucks on ipad
