Hello all, I hope that you can help with this issue.
First a list of the equipment involved
iPad - Wifi only. Used to run the Remote app.
Apple AirPort Express
Dlink D615R wire less router
PC - running Windows Vista - Media Edition - wired into the router
running iTunes
This is what happens, using the Remote app on the iPad I reach out and touch the iTunes on the PC, then send the music down to the Airport then to the stero. All works fine. I power off the iPad (enough music for one night) next day power on the iPad, wait for the wireless connection icon to appear, then try to use the Remote app to reach iTunes. Message - Cannot find library, iTunes is still running on the PC.
The iPad can surf the net. To regain access to the iTunes I either have to power cycle the DLink router, or the PC. Has anybody else had this problem? And if yes how did you solve it?
running iTunes
