Connecting iPad (4th Gen) to TV using USB cable
Discussion in 'iPAD Connect' started by AceLizard, Aug 10, 2013.
  1. AceLizard
    AceLizard
    Oct 4, 2011
    7
    Though I don't really want to watch movies or videos on the TV via the iPad, I would like to view my games on a larger medium. That being the case, my LCD TV has a USB port and I'd like to know if it's possible to connect the iPad to the TV without the added expense of purchasing the Lightning Adapter? The only thing I want to view are the games that I play - I don't really care about the rest (music, photos, videos, etc.).
  2. dhewson777
    dhewson777
    iPad Ninja
    Feb 23, 2012
    1,589
    163
    No, you cannot use the USB on the TV for mirroring your iPad. For one, the USB port on the TV is not set-up to do it, and neither is your sync cable for your iPad.
    You will either need the lightning to AV adaptor cable, or an Apple TV, which should both allow mirroring of your iPad screen.
  3. col.bris
    col.bris
    Staff Member
    Mar 25, 2010
    5,883
    690
    Apple TV is by far the best solution as it works with out wires..... Awesome product .....
connect ipad 4th gen to tv
connect ipad 4th generation to tv
connecting ipad how to connect ipad to tv with usb cable
how do i connect ipad 4th generation to tv
how to connect 4th generation ipad to tv
how to connect ipad 4th gen to tv
how to connect ipad 4th generation to tv
how to connect ipad to tv through usb
ipad 4th gen usb to tv connector
