Closing screens opened when double click in home button
Discussion in 'iPad 3 Forum' started by JPAD, May 12, 2014.
  1. JPAD
    JPAD
    Aug 4, 2010
    When I double click my home button I see open apps and different open screens from past searches . How can I
    close them? And what keeps them open in the first place?
    Thanks,
    John
  2. J. A.
    J. A.
    Staff Member
    Nov 11, 2012
    18,712
    11,172
    Hi, John! Welcome to iPF!
    You can close them this way:
    In iOS 6, tap and hold an app icon until they all start to wiggle. Delete them the way you would remove apps from your iPad.
    In iOS 7, slide the pictures above the app icon towards the top of the screen.
    This is called force closing apps.
    The apps in the multitask bar (that's what you see when you double tap the Home button) simply indicate which apps you opened or used recently. Most of them won't even load or keep on working in the background. They are in a suspended state. Usually you don't need to close them, just from time to time, if you're low on memory (RAM), or an app doesn't respond. Leaving them in the multitask bar is also very useful, because it allows to change between apps without having to press the Home button every time. Just perform a four finger swipe to the left or right, and you'll find the app you used before.
    Here's some more information about multitasking: http://support.apple.com/kb/HT4211
    Hope that helps.
    #2 J. A., May 12, 2014
  3. goofy8275
    goofy8275
    iPad Guru
    Aug 19, 2012
    2,598
    231
    Hello JPAD, I would like to welcome you to this amazing online community, in which thousands of fellow iPad enthusiasts from all walks of life come together to communicate about the Apple iPad.
    Please make sure you've read the Forum Rules:
    The iPad user manual for iBooks is a great place to start if you need help:
    https://itunes.apple.com/us/book/ipad-user-guide-for-ios-7.1/id709634245?mt=11
    Check out our iPad app for browsing iPF on the go:
    https://itunes.apple.com/us/app/discussion-forum-for-ipad/id412896524?mt=8
    I recommend subscribing to the iPF News Feed:
    http://www.ipadforums.net/index.php?pageid=apple_ipad_news
    We are glad you have joined, as we have a vast wealth of information at your disposal and a large community of members only too willing to help! :)
    -Goofy8275
    Sent from my iPod touch using iPF
double click ipad
double clicking home button on ipad 1 will not allow me to close apps
previous screens appearing slideshow doubleclicking home button ipad
