charging the battery
Discussion in 'iPad General Discussions' started by Mexicat, Jul 13, 2010.
  1. Mexicat
    Mexicat
    Jul 9, 2010
    5
    Does anyone know about how long it should take to charge the battery when it' plugged into a wall outlet?
    mine seems to take about 5 hours! Seems a long time........thanks
  2. gentlefury
    gentlefury
    iPad Guru
    Mar 15, 2010
    2,615
    7
    It takes about an hour or two from fully drained if you're using the iPad adapter...it's a lot long if you're using an iPhone adapter.
  3. martinc31415
    martinc31415
    Jun 24, 2010
    39
    I have nver fully drained mine but I had it down to about 19% one time. I think it took about 2 hours from there to full.
  4. kcleong18
    kcleong18
    Jul 6, 2010
    My first charge took 3 hours to give an indication of 80% battery capacity from a 25% start.I terminated the charge as I felt the iPad was too warm for my liking.
  5. Sonny Burnett
    Sonny Burnett
    Mar 7, 2010
    752
    I totally drained mine and it took more like 5 to 6 hours to get it back up to 100% and I was using the iPad wall charger.
  6. Applefreak12
    Applefreak12
    Jul 14, 2010
    16
    Five or six hours are ok.
battery drained ipad how long to begin charging
how long do you charge an ipad when the battery is drained
how long does it take an i pad to charge if it is totally doewn
how long does it take ipad to charge when fully drained
how long does it take to charge an ipad battery
how long does it take to recharge tablet battery is fully drained
how long should it take a completely powered down ipad to charge???
howlongdoesittaketocompletelyrechargeanipadbattery
if an ipad battery is drained how long does it take to charge and come on
will ipad work when plugged in to a wall outlet even if battery is completely drained
