Charging problems
Discussion in 'iPad Help' started by Amy Rose The Hedgehog, Jun 22, 2012.
  1. Amy Rose The Hedgehog
    iPad Ninja
    Jun 22, 2012
    1,615
    20
    I guys, I'm having troubles with my iPad charging. I will put it on the charger and set it down gently, then it starts charging and not charging on and off and off it gets a little frustrating after a while, I tried to reboot it didn't work. Then eventually a yellow triangle with a black exclamation mark in the middle pops up and under it it says " this accessory is unable to be charged "
    Can anyone help me for why it does this? :/
  2. lollie
    lollie
    Sep 8, 2012
    Hi I have the same problem when i plug my charger into wall outlet it say this charging is not supported with this accessory it is the orginal charger came with it please can anyone help me i am new to this forum .
    Lollie
ipad 1 charger error yellow triangle
ipad 1charger says not supported with this accessorie
ipad accessory is unable
ipad triangle with exclamation point
ipad wont charge yellow triangle
yellow triangle on my ipad
