Charging problems
Discussion in 'iPad Help' started by Dianeleslie, Jan 19, 2012.
  1. Dianeleslie
    Dianeleslie
    Jan 19, 2012
    For some reason my iPad will not charge using the cord and any wall sockets.
    It was fine yesterday but now I plug it in, it briefly shows the charging symbol and switches to 'not charging'
    Any ideas or suggestions?
    Diane
  2. Amy Rose The Hedgehog
    iPad Ninja
    Jun 22, 2012
    1,616
    20
    Maybe it has something to do with the charger, I had an old iPad charger, it bent at the top where the plug was, and the charger couldn't charge because of it, so I had to replace the charger, because it was very difficult to get it to charge, it took me like 10 minutes each time to get it to charge, so I would suggest checking to see if there's anything strange about the charger.
  3. AllenSalar
    AllenSalar
    Jul 13, 2012
    358
    19
    Try comparing with friend's charger first, just to make sure :)...
  4. 5er driver
    5er driver
    Nov 29, 2010
    94
    I've had this issue since day one with my iPad 3 and the original 11 watt wall charger and docking cable that came with it. I also have several original Apple 11 watt chargers and cables throughout the house and have the same issue with them. I do this though, and it works for me every time. Before charging, pull the wall charger out of the 120/240V supply. Pull the docking cable out of the iPad. Short the two blades of the charger together in the palm of your hand or put a finger across them for a couple of seconds. Don't worry, you won't feel any electricity. Then plug the cable into the iPad, then the charger into the 120/240V power supply. I don't know why this works for me but it does. Let us know if this works for you.
    Sent from my iPhone 4S or iPad 3rd gen, whichever I happened to have in my hands at the time, using iPF.net
apple ipad charging problems
charging problems i pad
i pad problems charger cord
ipad charger cord problems
