Changing Safari Search Engine ?
Discussion in 'iPad Help' started by darkheroz, Aug 28, 2011.
  1. darkheroz
    darkheroz
    Aug 15, 2011
    10
    Hello,
    I want to change search engine in Safari, BUT not to Yahoo or Bing. I need to change it to google but in my language - bulgarian. For example when I search word "dnevnik" in google.com 1st result is - dnevnik.hr
    in google.bg result is - dnevnik.bg
    google top toolbar is also different - in english and in bulgarian.
    So I need help to change this preferences.
    I find and edit some plist but without effect.
    10x in advance
  2. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,892
    2,224
    The only way I know to change the search engine is to go to the Safari settings in the Settings app. In there is an option to change the search engine. Maybe if your iPad's language is not English it'll sow the Google for your language. I don't know this though....
    If that doesn't work, I figure you'll have to create a bookmark for the Google you want. You won't be able to search it from the search box but at least you'll be starting at the right place.
    Good luck and let us know how you get on.
  3. darkheroz
    darkheroz
    Aug 15, 2011
    10
    Hello Mickey,
    I already have bookmark for google.bg and it works fine :)
    My IPAD lang is already bulgarian, but this doent effect on safari search engine :(
    10x for advise :)
  4. darkheroz
    darkheroz
    Aug 15, 2011
    10
    YES ! You are right, my Ipad lang menus was English. When I changed it to Bulgarian
    safari change search form :) 10x a lot !!!
change from bing to google on ipad ios7
change ipad search to google
change search engine from bing to google ipad
change search engine from bing to google on ipad
how do i change from bing to google search on ipad
how to change from bing to google on ipad
how to change ipad safari search engine
how to change ipad search engine to google
how to change search engine to google on ipad
ipad search engine keeps changing to yahoo
