Can I use the camera connection kit to mount a sd card fat32 to play .avi movies?
Discussion in 'iPad 3 Forum' started by kidio007, May 6, 2012.
  1. kidio007
    kidio007
    May 6, 2012
    Hi, was just wondering if I can use the camera connection kit to mount a sd card with fat32 format and play a .avi movie using avplayerhd directly from the sd card?
    Thanks.
  2. AQ_OC
    AQ_OC
    iPad Wizard
    Apr 28, 2011
    6,411
    431
    I don't think so.
  3. NakedFaerie
    NakedFaerie
    Sep 22, 2010
    65
    it looks like you cant play it directly from a SD card but you can copy it from a SD card to the ipad. i used iFile from Cydia to do that.
    you can click the AVI file in iFile and it will popup asking what to open it with. i couldnt open it but it did copy and play using AV Player HD.
  4. Wolfpuppies3
    Wolfpuppies3
    Aug 9, 2010
    732
    10
    Very easy to do - just place the SD card in your AirStash and wifi connect it to the iPad.
  5. AQ_OC
    AQ_OC
    iPad Wizard
    Apr 28, 2011
    6,411
    431
    Well, yes, if you put it that way! :)
apple camera connection kit mount point
how do you play a movie file on road using camera connection kit
mount point apple connection kit
mount sdcard ipad
sd card mount in ifile
