Can I listen to tunes from my ipad through the car stereo using bluetooth?
Discussion in 'iPad General Discussions' started by Wonkeyman, May 15, 2011.
  1. Wonkeyman
    Wonkeyman
    May 15, 2011
    I have a car stereo which has bluetooth (Kenwood KDC BT30) and i'm about to buy an ipad (not an ipad2 but the original with 3g and 64gigs) and I was wondering wether I could use the Bluetooth to link the ipad and have tunes coming through the car speakers without using auxilery wires??
    The stereo can pick up phone calls and put them through the car stereo but doesn't mentune about ipads and music.
  2. Eviljunkee
    Eviljunkee
    May 12, 2011
    16
    Someone correct me if I'm wrong, but I think your stereo needs to have AD2P capabilities in order to play music through it using your iPad...
  3. Jeeper
    Jeeper
    Nov 14, 2010
    436
    8
    That's a interesting thought, I don't know enough about Bluetooth to answer you. But I have found that my iPad can play through my iPod adapter in the car. Music as well as games and video plays through the speakers (kinda cool).
  4. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,651
    35
    If your iPad can connect to it it should. I am not a Bluetooth expert though. :(
  5. Mountainbikermark
    Mountainbikermark
    iPad Addict
    Mar 10, 2011
    1,392
    6
    That is correct. A quick look online at the stereo model number specs should reveal if it has a2dp
    http://www.kenwood-electronics.co.uk/products/car/cd_receivers/cd/KDC-BT30/
    Support Our Troops!
    This post was Tapatalk approved
    #5 Mountainbikermark, May 15, 2011
  6. saphire
    saphire
    Feb 2, 2011
    207
    28
    I plug mine in through the headphone socket to, I put the radio on aux and play, works a treat.
  7. Harley man
    Harley man
    Mar 16, 2011
    345
    That's right I do the same thing works good
  8. pilgrim
    pilgrim
    May 16, 2011
    Can I play the ipad through the Belkin FM Tuner that I use for my ipod?
  9. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,651
    35
    It should definitely work. It wont hurt to try.
  10. DontUnderstandMyIpad
    iPad Guru
    Jan 22, 2011
    3,192
    13
    It should work, but just to clarify, which version of the Belkin FM Tuner do you have? The one that goes into the 30-pin slot, or one that goes into the audiojack?
    If it is the one connecting to the audiojack, it will definitely work. If it is the one connecting to the 30-pin slot, it should work, but there could be some compatibility issues, so there is no guarantuee that it will work.
bluetooth ipad to car stereo
can i play my ipad mini music thru the car radio
can i use my ipad air as a ipod in my car
can i use my ipad mini for music in my car
can you play ipad songs on car bluetooth stereo system
how do i play music from my ipad in my car
how do i play my ipad in my car
how do i play my ipad through my car stereo
how to play music from my ipad in my car
play ipad music through bluetooth
