Camera Connection Kit
Discussion in 'iPad OS' started by jackpg, Nov 27, 2010.
  1. jackpg
    jackpg
    Nov 20, 2010
    Hi,
    has anyone had problems with the camera connection kit? First set did not work and I returned them and the new ones don't work either. Get the message that they are not compatible and to dismiss. Called Apple and get a run around. Person on phone did not know anything about problem and gave another number that never seems to answer. Thanks for any help.:(
  2. MarkK
    MarkK
    Sep 20, 2010
    102
    Works fine for me.
    What did you do when this message showed up?
    Did you connect a camera or an SD-card?
    An SD-card must be formatted in a camera first to work.
    It needs the DCIM-folder. If this folder exists, the iPad will look for pictures in this folder.
    If not, it will show the error you had.
  3. jackpg
    jackpg
    Nov 20, 2010
    Thanks Mark,
    my camera uses CF card so formatted card in computer. Still get the same error. Thanks for your help
  4. DUTCH VanAtlanta
    DUTCH VanAtlanta
    Jun 12, 2010
    96
    My cameras - all various Canon EOS models, now EOS 7D - all recommended formatting the CF card in the camera for best results.
  5. jackpg
    jackpg
    Nov 20, 2010
    Format Card
    Dutch, I was referring to the SD card that I formatted in the computer. I have no camera to format it. I then copied pictures to it and they work fine between computers, but not IPad. Thanks for your input.
cf card
