Camera Connection Kit Problem
Discussion in 'iPad Help' started by Richard599, Apr 28, 2011.
  1. Richard599
    Richard599
    Apr 28, 2011
    I have a new iPad 2 and am really enjoying the iPad experience. However, I am having a problem importing “JPG†pictures from the SD Card reader purchased with the “Camera Connection Kitâ€. The pictures work OK on the SD Card interfaced to my PC. I am following the instructions exactly as explained (Lock the iPad, insert the SD Card Reader, insert the SD Card in the Card Reader, Unlock the iPad). Nothing happens on the iPad (it just opens to the home screen). I have saved some photos from e-mails and with the Sony Cybershot interfaced directly to the USB Adapter that comes with the “Camera Connection Kitâ€. Further, I can view those photos. However I cannot successfully import photos via the SD Card Reader. I visited an Apple Retail Store and had them check it out. My SD Card reader purchased with the “Camera Connection Kit†worked with their SD Flash card, but not with my two. I had them format my SD card and import one of their photos to it so I could try that particular SD Card in my SD card reader. No luck with my iPad 2. They suggested I purchase a new SD Flash Card. I did. I purchased 2 Sony SD Cards and have the same results (do not work). Question, has any one else experienced this? Does any one have any suggestions? Is there a particular MFG SD Flash card that needs to be used? Or, perhaps, the SD Flash card need to be formatted a special way?
    By the way, I have two calls into the Apple Support Line and have been waiting for a call back for 10 days. Thanks, Richard
  2. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    I have 2 32GB play.com branded SD cards, both of which work fine in the photos app and with iFile (jailbroken) iPad1.
    Ensure your card is formatted on FAT/FAT32. Don't know what else to suggest. Sorry.
  3. DontUnderstandMyIpad
    iPad Guru
    Jan 22, 2011
    3,192
    13
    What filenames do the images have?
    The photos app is really picky and will only except IMG_1234.jpg images, where 1234 can be any number.
  4. bearswatchin
    bearswatchin
    Nov 19, 2010
    23
    Try making a /DCIM directory on the card and put the .jpeg in it.
  5. incapete
    incapete
    Apr 25, 2011
    109
    So you're having trouble viewing photos that you've copied from the PC to the SD? And SD cards coming straight from other cameras work ok?
    The SD card needs to be structured as if it's coming straight from the camera so the photos need to be in a folder called "DCIM" and follow the naming convention "IMG_1234.jpg".
    If you just load files into the root of the card, or have renamed them to something more personal then they won't display on the card.
  6. DontUnderstandMyIpad
    iPad Guru
    Jan 22, 2011
    3,192
    13
  7. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    It's done..thanks for spotting this, DontUnderstandMyIpad
    #7 Tim SPRACKLEN, Apr 29, 2011
apple ipad camera connection kit problems
apple lightning to sd card camera reader problems
ipad camera connection kit problem importing videos
ipad no photos to import
ipad no photos to import dcim camera kit
ipad says no photos to import
ipad says no photos to import from sd card
ipad sd card reader no photos to import
problems with ipad camera connection kit
sd card reader says no photos to import
