Have a look at
'Settings', 'Mail, Contacts, Calendars', 'Time Zone Support'.
Here you can set the calendar time zone to be forced to adhere to what you set it to manually or automatic. See what you've got the time zone set to and if it's appropriate. If all that checks out and there's still a problem then the 'age old solution' of a reset often helps....
