Battery?
Discussion in 'iPad Air 2 Forum' started by HUNTER1, Dec 16, 2014.
  1. HUNTER1
    HUNTER1
    Jul 21, 2010
    228
    10
    The first two days I played games, the the battery went down to 20% quick but I thought was reasonable and recharged it. Played games again and the battery discharged to less than 20% at the same rate. But now after I recharged the third time, the battery is lasting more than twice as long even after many hours of playing games. I read that the battery needs conditioning by letting it discharged to less than 20%, is that what happened here? thanks
  2. Jerry Osser
    Jerry Osser
    Dec 12, 2014
    6
    This is my first ipad,got over 10hrs with 20% left
  3. HUNTER1
    HUNTER1
    Jul 21, 2010
    228
    10
    I meant to put this in the iPad air 2 section. anyway, just wondering why the first two charge were discharging much faster than the charge after that.
  4. Jerry Osser
    Jerry Osser
    Dec 12, 2014
    6
    I have the air 2
  5. skimonkey
    skimonkey
    Staff Member
    Sep 11, 2011
    18,940
    1,405
    Hi Hunter-I've moved your thread to the ipad Air 2 section now.
    Ski
  6. HUNTER1
    HUNTER1
    Jul 21, 2010
    228
    10
  7. giradman
    giradman
    iPad Wizard
    Apr 26, 2011
    6,981
    6,230
    Modern lithium-ion batteries do not need to be 'conditioned' nor do they have 'memory issues' that plagued previous battery technologies (all of my cordless power tools have only Li-Ion batteries now). Apple does suggest a complete discharge/recharge (i.e. complete cycle) about once a month which calibrates battery monitoring properly. Depending on the device (i.e. iPad vs. Macbook), Li-Ion batteries taken through 500-1000 of these cycles will maintain about 80% of their capacity (measured in mAh).
    Now, as to your experience w/ rapid and then slower loss of battery power, I have no answer; might have related to the games being played or to other features that were activated, e.g. Wi-Fi/Bluetooth radios on, screen brightness, push notifications, et al? If interested, you might want to obtain a 'battery app' (check the App Store) - I have two on my iPad. At the moment, my iPad Air 2 is 92% charged and the app shows that I can listen to 27 hrs of music, but do just 5 hrs of 3D games. Dave :)
