Battery Charge Time and Depletion
Discussion in 'iPad 2 Forum' started by Zmanga, Mar 24, 2011.
  1. Zmanga
    Zmanga
    Mar 2, 2011
    12
    So the battery should last 10 hours, but,
    HOW LONG does it take to charge once it is fully depleted?
    Also, I've been told that you should let your battery run completely out at least once a month, then recharge. Since it will go into sleep if you are not using it, what do you run on it so it will stay on and run down the battery?
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    If you want your iPad to stay on and not go to sleep
    'Settings', 'Autolock', 'Never' will keep it on all the time.
  3. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    Sorry, not my day today....
    'Settings', 'General', 'Autolock', 'Never'...
  4. DontUnderstandMyIpad
    iPad Guru
    Jan 22, 2011
    3,192
    13
    Isn't it around 4am? At least that's the current time in the Scotland I live in :)
    To run down the battery, either leave the iPad on, as Tim described above or just don't charge the iPad until the battery runs low.
  5. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    Indeed it is just after 4am - but a moderator's day is never over......:)
  6. Zmanga
    Zmanga
    Mar 2, 2011
    12
    WOW - thanks for the QUICK responses.
    I realize I could just wait til the battery ran down over time, but I like to keep it at a full charge so I have plenty of battery time.
    So, I thought I should periodically FORCE the battery to run out.
    Is this right? Or should I just charge it back up every night?
    So, do I need to make the battery run all the way out or not?
    If I do, I can just make the changes above to not let it go to sleep.
  7. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
  8. DontUnderstandMyIpad
    iPad Guru
    Jan 22, 2011
    3,192
    13
    You can just charge the iPad every night.
    The only reason to let the iPad's battery run low would be for the iPad to recalibrate the battery. The battery % is an approximation based on the voltage supplied by the battery, as the battery gets used the voltage slowly decreases. A used battery will even when fully charged, supply a lower voltage, so essentially this changes the voltage range in which the device can operate. When the device is uncalibrated, it is possible that a fully charged iPad shows less than 100%, because due to wear the battery cannot supply the voltage linked to 100%. So running the battery completely down simply tells the device in what voltage range it operates. But generally there is no need for this recalibration and should only be done, if you feel that the battery percentage is wrong.
    #8 DontUnderstandMyIpad, Mar 24, 2011
average battery depletion rate for tablet
does the battery on the ipad need to be fully charged every time you chart
how long charge battery depleted tablet
i pad 1 depleted battery, recharging time?
if you charge ipad all the time does it deplete the battery
ipad 2 charge time
ipad battery how to deplete
ipad fully depleted
what is average length of time for i pad battery before need to recharge
what percentage should i charge the battery get on rca tablet
