Battery Care
Discussion in 'iPad General Discussions' started by mossman, May 3, 2010.
  1. Edlex
    Edlex
    Mar 22, 2010
    596
    I guess the best advice is charge whenever you want. Other than depleting it to zero often or never unplugging it you really can't hurt these batteries. Charging it often can't hurt them.
  2. ayerbusiness
    ayerbusiness
    May 8, 2010
    68
    although I already have my iPad, I Am not sure with the right answer to all of your questions. But I would suggest that you would visit sites for the Apple iPad for more information regarding your battery.
  3. Zardoz
    Zardoz
    Apr 14, 2010
    22
    Try and not do Full cycle charging also there is no need to charge 100% every time running 90 to 40% is best as always you might have some venation and that's fine. if you are going to storage the unit charge it to about mid level.
apple ipad battery care
battery forum
can i over charge my ipad
can i overcharge ipad
can i overcharge my ipad
can you overcharge an ipad
ipad battery care
is it possible to overcharge an ipad
overcharging ipad
what happens if i overcharge my ipad
