auto start of itunes stopped working
Discussion in 'iPad Help' started by jrw, Jun 27, 2010.
  1. jrw
    jrw
    Mar 26, 2010
    23
    All of a sudden when I attach my Ipad, Itunes will not start.(has been working since launch day of the Ipad) If I manually start Itunes all is well.
    I have confirmed that the Itunes will start when Ipad is plugged in check box is checked.
    Using the latest Itunes 9.2.0.61
    What am I doing wrong here?
  2. iPadCharlie
    iPadCharlie
    iPad Super Guru
    Jun 19, 2010
    4,231
    7
    If you are running a Windows-based machine, it might be time to give it the old three finger salute!
  3. jrw
    jrw
    Mar 26, 2010
    23
    Yes running Windows 7 and the three finger salute will work, but have to do this reboot each time I connect my Ipad. Workaround for sure but not a solution to my frustrating issue.
  4. jrw
    jrw
    Mar 26, 2010
    23
    bump,,,
    I cannot be the only one with this issue.
    Connecting my Ipad to my PC will no longer start itunes automatically. I have the setting set to do this and it was doing this for a long time.
    I am running win 7 and I know this is a apple based forum, but does anyone have a idea on how to solve this.
  5. kierandill
    kierandill
    Jun 20, 2010
    189
    Is there a process dying when you disconnect? I believe in Windows there should be an iTunesHelper.exe running in task manager. Sorry, I'm at work or I could check my Vista media center.
    Also, I believe there is a setting in iTunes itself to toggle auto start on plugin.
  6. Matth3w
    Matth3w
    iPad Ninja
    May 26, 2010
    2,017
  7. jrw
    jrw
    Mar 26, 2010
    23
    The process will let me sync after I manually start itunes and will tell me sync is done and I can disconnect the Ipad.
    I have searched for iTunesHelper.exe, it is not listed in the task manager and I cannot find it at all on the system. Listed in the task manager is itunesmobileservice.dll which is running.
    #7 jrw, Jul 2, 2010
  8. jrw
    jrw
    Mar 26, 2010
    23
    I checked and no ituneshelper in msconfig. Listed is ipod service which is running. and ipod
as soon as i plug in my iphone itunes is not working
autostart itunes
itunes does not startup when attaching ipad
itunes not opening when pluggin in ipad
wen i plug in my ipad to windows 7 autoplay does not run
why does ipad auto start music
why does itunes not auto start
why does itunes stop working when i start it
win 7 not auto start ipad
windows 8, open itunes when ipad plugged in
