Audio Volume
Harreec
Ottawa,Canada
I use a metronome app and I can't get enough volume from the built in speaker. Can I plug into the headphone jack and connect to an external speaker of some type.
thank you
ian russell
UK
thank you
You can plug it into the AUX input of your hi-fi or amp. That's how I listen to radio stations. The amp will boost the volume. You probably need a cable with a 3.5mm jack on one end and whatever jacks you have on your amp on the other; readily availabe from most electronic stores.
