Audio on i pad 2 connected to LCD projector
Discussion in 'iPad 2 Forum' started by David1965, Dec 13, 2011.
  1. David1965
    David1965
    Nov 23, 2011
    14
    Got my i pad 2 to VGA connector - plugged it in - video is great but no sound (except from the i pad itself). Any ideas? Audio works fine when the computer is plugged to the projection system (it plays over the speakers). This is also my wife's ipad which is running i OS 4.3.3. Would 5.0 help?
    Thanks in advance!!
  2. kingnba6
    kingnba6
    May 17, 2011
    877
    7
    Hm do you have a link to the VGA cable. Are you talking about the computer monitor cable? If so, that cable does no carry audio.
  3. David1965
    David1965
    Nov 23, 2011
    14
    Yes, the cable that goes from the ipad to the VGA connector. So how could I get audio on the projection system speakers? Without audio on the big speakers it will not be heard. I'm sure there is a way.
  4. kingnba6
    kingnba6
    May 17, 2011
    877
    7
    This is what I got from the site: The Apple VGA Adapter supports video out (only). You have to but a separate 3.5mm audio cable. Plug that into the headphone jack of the iPad and then to the projection system. How is your computer connected ? Thru VGA or something else ?
  5. David1965
    David1965
    Nov 23, 2011
    14
    This one is VGA, others are DVI but I have all the adapter combinations known to man. I try the cable now!
  6. David1965
    David1965
    Nov 23, 2011
    14
    Just tried it and BINGO...worked great!! Just needed that audio cable plugged from the computer to the headphone jack on the ipad. Thanks kingnba6!
  7. kingnba6
    kingnba6
    May 17, 2011
    877
    7
    no problem. always looking to help
connecting ipad to projector no sound
ipad apple tv projector no sound
ipad apple tv projector no speakers
ipad to projector but no sounf
ipad to projector sound system
lcd projector ipad no sound
more volume ipad vga connector to projector sound
my i pad connected to projector has sound but no video
sound from ipad to lcd with speaker
