Audio books , iPad mini
Johnty1
  1. Hi, l am new to apple products this is my first iPad, normally l use a laptop with Bluetooth earphones to listen to audio books as i work around the room, when I try to use the mini iPad with Bluetooth earphones it switchs off after a couple of minutes unless l hold and keep contact with the screen, defeats the object of wireless headphones, is it possible to keep the iPad on while its reading a book ? Thanks jonty
Milton-Freewater, OR
This should not be happening. Most audio apps will continue to play audio after the iPad's screen goes to sleep.
What app are you using to listen to audio books?
scifan57
Regina,Canada
I use the Audible app for listening to my audiobooks. It continues to play in the background whatever else I'm doing. The only exception is if I go to a website or use an app, such as YouTube, that also has audio content.
J
Johnty1
Hi, l think it's the iBook app, it's the one that's comes pre-loaded with iPad ,I have not downloaded any apps, thanks for your reply
J
Johnty1
Hi, thanks for the reply, is the app you use all ready pre-loaded or is it a down loaded app ? Thanks
scifan57
Regina,Canada
The Audible app is developed by Amazon and is a free download in the App Store. Amazon has an Audible store on their website where you can purchase audiobooks. Once purchased, the audiobooks are downloadable to any of your devices at no extra charge. You can also download the audiobooks to any Kindle ebook reader you may own.
scifan57
Regina,Canada
Audio books in the iBooks app continue to play in the background on my iPad.
Hmm. In that case it sounds more like it's a Bluetooth rather than an app problem. Could be the iPad, the headphones, or a bit of both. In my experience the reliability bluetooth headphones varies a lot from brand to brand. (my experience being limited to two fairly cheap sets).
Try forgetting and re-pairing the bluetooth headphones in Settings > Bluetooth. Make sure the set is fully charged. Keep an eye on your distance from the iPad when it goes out. Might be a range issue.
J
Johnty1
The Audible app is developed by Amazon and is a free download in the App Store. Amazon has an Audible store on their website where you can purchase audiobooks. Once purchased, the audiobooks are downloadable to any of your devices at no extra charge. You can also download the audiobooks to any Kindle ebook reader you may own.[/QUOTE
That sounds interesting, the headset is new, a cheap generic no name brand, from the Internet , I bought anew set because the old iTech Bluetooth set would not pair with the iPad though the ipad would discover it, the iTech is a few years old so anew set seemed the way to go. Sometimes one gets what they pay for.
I will try the iPad with plug in ear phones and see what happens while sourcing a branded set, Thanh you very much for your help, l would never thought of earphones as they are new
Good luck. Let us know how it goes.
Disclaimer: I didn't say it 'was' the earphones. I just suggested it might be. Please don't hit me if the new ones don't work either.
J
Johnty1
Hi, no I realise you only suggested that it may be the earphones as part of your diagnostic work through, what I should have mentioned after your alert I then tried them on my mobile phone with music and sure enough after a couple of minutes it would shut down, l tried it several times with the same result, i have learned a lot from this thread,
