Another sync problem
Discussion in 'iPad Help' started by DEKA2010, Oct 16, 2011.
  1. DEKA2010
    DEKA2010
    Oct 8, 2011
    12
    MY IPad still don't look the same as it did in ITunes, no matter how many times I soft reset and hard reset, it won't work out, but I keep downloading free apps, but unfortunately unless someone here give a right clue to transfer or sync to my IPad, they will only stuck in ITunes library
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    I've moved this to the Help section, where I think it will receive better attention.
  3. DEKA2010
    DEKA2010
    Oct 8, 2011
    12
    Yeah thanks, hoped someone will assist me to solve the problem
  4. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,859
    6,877
    Under the Store menu in iTunes, make sure your computer is authorized. At the top right, make sure you are logged into the store with the same account that you use on the iPad. If by chance you were logged into another account, hold in mind that any app purchased under another account and synced to your iPad will not update on the iPad unless you also chance it's account invthe store.
    With the iPad connected, select it under the Devices list, go to the Apps section at the top. Make sure that you have app syncing turned on, and that all the apps you want on the iPad have checkmarks next to them.
    If you have apps on the iPad that are not in iTunes, right click on the device and choose Transfer Purchases. Do this be for you sync or turn on App Syncing.
