Another question for ipad battery
Discussion in 'iPad Help' started by BlackOropher26, Dec 26, 2012.
  1. BlackOropher26
    BlackOropher26
    Oct 31, 2012
    114
    So i've been using my ipad for 4hours straight (from 100 till 60) and its obviously consuming 10 of the battery every 1 hour.is this normal for an ipad 3? As far as i know,it can run for 10hrs.Btw,i'm just using multiple apps (facebook,twitter and facetime) at the same time.
  2. Gabriel1
    Gabriel1
    iPad Legend
    Mar 11, 2011
    17,092
    747
    Yes, this is fairly standard.
  3. BlackOropher26
    BlackOropher26
    Oct 31, 2012
    114
    And does it decrease even more if there are multiple tabs/social networking apps running at the same time?
  4. Gabriel1
    Gabriel1
    iPad Legend
    Mar 11, 2011
    17,092
    747
    It's entirely dependent on how hard the processor is working, screen brightness, sound level, wifi usage, etc.......if you are roughly using 10%/hr then you have nothing to be concerned about. If you are using a lot more than this you need to look at how bright your screen is, what apps are running, etc.
