Airprint help
Discussion in 'iPad OS' started by Mike_73, Dec 13, 2010.
  1. Mike_73
    Mike_73
    Sep 6, 2010
    189
    Since updating to itunes 10.1 final and ios 4.2.1 final, I cannot print via my network. I tried to install manually, I tried to use different "airprint activators" but none of them work. Even my iPad crashes when I try printing from pages.
    It worked with itunes 10.1 beta 2 and ios 4.2 beta 3. Is there a way I can permanently use those installs instead of the final versions?
    In itunes 10.1 beta 2 there was actually a section where you could enable airprint and it worked.
    Any ideas?
  2. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,651
    35
  3. Mike_73
    Mike_73
    Sep 6, 2010
    189
    That's exactly what I did before.
    So my iPad can see the printer, but when I hit print in safari, I don't get a printout, and if I try it in pages, the app actually crashes. :(
  4. Jax
    Jax
    Nov 13, 2010
    14
    Mine shows the printer, but asks for a name and password for printer. I have no idea where it gets this. There is no password on printer that I know of.
  5. DaveSt
    DaveSt
    Sep 14, 2010
    626
    The user name/password AirPrint is asking for is actually whatever your login is for the computer the printer is attached to.
    I sure hope this isn't Apple's final answer to printing from the iPad. My old Windows 3.1 machine had better printing support than this solution provides.
  6. Jax
    Jax
    Nov 13, 2010
    14
    The problem is I don't use passwords on my computers so there is none. I did go to "Printer" and check sharing with out a pass word, thought that would fix it. Still no work.
  7. BrennB
    BrennB
    iPad Addict
    Jun 13, 2010
    1,278
    6
    just enable a guest account on your computer and the password popup will go away.
  8. Mike_73
    Mike_73
    Sep 6, 2010
    189
    I had this, too, while I ran all beta versions of iTunes and iOs 4.x.
    Just enter the computer name (the name of your main data folder in windows) and leave the password empty. That's what I did.
    But ever since I upgraded to the final versions, I can see and select my printer on the iPad, but I cannot print anything. Well, iPad tells me it's done, but my printer doesn't print. :(
  9. Towmoter
    Towmoter
    Dec 29, 2010
    I have a little different problem with Air Print and cannot find the answer. Prior to Air Print I installed a App called Print Magic. It recognized my printer right away but with Air Print it does not recognize the printer. Anyone have a solution?
  10. BrennB
    BrennB
    iPad Addict
    Jun 13, 2010
    1,278
    6
    so you're saying that you enabled AirPrint and not print magic can't find the printer? Or just since the upgrade Printmagic can't find the printer?
airprint activator user name password
airprint help
how do i install an airprint printer on my ipad
how to install airprint activator 2 in my i pad
instalar airprint
