About charging battery to the ipad
Discussion in 'iPad Help' started by Tes, Jan 25, 2011.
  1. Tes
    Tes
    Jan 25, 2011
    21
    Is there any problem,if my ipad remains pluged in to the charger,as long as I am at home.
    my second quetion:Is there any disadvantage that I could get ,if I charge my ipad in what ever level it is for eg. if it is 60% or 80% or what ever it is or I have to wait ,untel it reaches to the minimum?
  2. MaDurn
    MaDurn
    Jan 20, 2011
    14
    Tes, in the 2wks that i have had my ipad, i have ran the battery down twice....im not really sure if there would be a disadvantage. ive run down the battery on ipods plenty of time....but im not expert. hopefully someone else could weigh in....
  3. twerppoet
    iPad Legend II
    Jan 8, 2011
    21,231
    7,475
    Charge it as often as you like at whatever level. Lithium ion batteries don't have memory. You are more likely to shorten the battery life by fully discharging it too often, but you'd really have to do it a lot to have a significant impact. Just plug it in whenever it is convenient.
    It is recommended that you occasionally discharge the batter until the device shuts down automatically. Then you should charge it to 100%. This isn't for battery life, but to keep the battery status software on the iPad in calibrated. Once on month is more than enough, or whenever battery life and the charge indicator seem to be out of sync.
  4. Tes
    Tes
    Jan 25, 2011
    21
    Thank you, would you please give more explanation?
  5. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,234
    122
    Here's the 'official line' from the Apple Web site
    Apple - Batteries
  6. peled
    peled
    Oct 31, 2010
    890
    Once the iPAD gets to 80% , it will start charging in a much slower pace.
    Despite what every one says, you can charge it with a USB connection to any PC, with a program named "ASUS Ai Charger"
  7. Tes
    Tes
    Jan 25, 2011
    21
    "with a program named "ASUS Ai Charger" How and where do I get this?
  8. peled
    peled
    Oct 31, 2010
    890
  9. ctsluder
    ctsluder
    Nov 11, 2010
    102
    Thank you!!! 
  10. David79
    David79
    Jan 11, 2011
    758
    I keep hearing about fast charging to 80% then trickle charge to full, I know what it means, but my iphone 3gs and ipad has never taken more then 2 hours total even from dead or almost dead to charge to 100%, so is there something wrong? or is that just some take longer then others to charge?
asus ai charger disadvantage
can i charge my ipad in germany
charging my ipad in germany
how can i tell if my ipad is charging
how can tell dead ipad charging
how do i know if my ipad battery is dead
how do i know if my ipad is charging
how do i know my ipad is charging
how to charge ipad in germany
how to tell if a dead ipad is charging
