A Battery Question
Discussion in 'iPad 2 Forum' started by Knightoftheapp, Apr 25, 2011.
  1. Knightoftheapp
    Knightoftheapp
    Apr 7, 2011
    437
    15
    I'm getting my iPad 2 in roughly 90 minutes after waiting for 3 1/2
    weeks. :D
    My question is about the battery. It use to be that you had to charge up the battery of whatever tech that you were using for a full 18 to 24 hours before you used the tech in question. This was required for the battery to hold a full charge. I am, of course talking about the old nickle cadmium batteries. Is it neccesarry to fully charge the iPad like that before I use it or (once I sync it) can I use the machine right out of the box? Thanks.
  2. SweetPoison
    SweetPoison
    iPad Legend
    Jun 20, 2010
    14,913
    133
    Yay!
    You can use it right out of the box, I think I did. But I can't remember how much charge it came with ~
    But why not just charge it?
  3. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,236
    122
    An iPad battery comes, more-or-less, fully charged. There's no need for any special precautions. Charge as often - or as infrequently - as you like. The iPad is 21st century, so none of those old precautions apply. Apple want you to be happy so they used some ultra-sophisticated battery charging electronics in the iPad. Leave it on charge all day - no problem. Let the battery go completely flat - no problem (though you'll need to charge it before you use it then, even Apple can't control the Laws of Physics - yet!).
    But, don't believe me, read the official line...
    Apple - Batteries - iPad
  4. Gabriel1
    Gabriel1
    iPad Legend
    Mar 11, 2011
    17,095
    747
    Like Mrs P says, use it right out of the box, once it's synced stick it on charge while you play with it......don't forget it has to be plugged into the mains to charge, it won't charge through the USB but it will hold it's charge b
  5. Knightoftheapp
    Knightoftheapp
    Apr 7, 2011
    437
    15
    Thank to all of you for your help. This is the first Apple product I've ever bought so I got a lot to learn.
  6. Gazzaho
    Gazzaho
    Mar 11, 2011
    119
    It will charge from a USB port on a computer but at a slower rate, it says its not charging but it is, it just takes longer, I've read however that if using it while plugged into the USB, depending on what you're running at the time, it may not charge. Apple also recommend running the battery out, and a full recharge once a month to keep the battery meter calibrated. Mine also came fully charged out of the box.
    A direct quote from Apples battery page.
    Use Your iPad Regularly
    For proper reporting of the battery’s state of charge, be sure to go through at least one charge cycle per month (charging the battery to 100% and then completely running it down).
    #6 Gazzaho, Apr 25, 2011
  7. tzimisce
    tzimisce
    iPad Addict
    Sep 23, 2010
    1,078
    A friend had a problem with the device's battery meter: no matter how much he charged it, it always showed 2% (obviously not the case). A reset fixed the problem.
  8. SporkLover
    SporkLover
    Mar 11, 2011
    138
    It's a lithium ion battery; that full charge rule applies to older nickel based batteries.
    Nickel based batteries needed this because nickel is a "memory" metal that needed full charge and discharge cycles for it to remember it's capacity.
    Lithium based batteries are "smart". They have electronics in them to tell when it's full or discharged. Lithium batteries need to be discharged and charged fully every so often so that the smart circuitry can re calibrate (it will account for any battery degradation, which will happen).
  9. Hasty
    Hasty
    iPad Ninja
    Jun 2, 2010
    2,266
    22
    I ran an iPad1 for last year without a full discharge and no obvious bad effects.
    Battery life appears as good as it was when bought.
ipad battery charged out of box
ipad out of the box charging
