5 Dollar Stand/Charger Review...
Discussion in 'iPad Accessories for iPAD 1, 2 and 3' started by Ultrimate, Jul 30, 2010.
  1. Ultrimate
    Ultrimate
    Jun 10, 2010
    396
    Hello, recently I posted a 5 dollar stand/charger, I received today and this is the review..
    First off, like someone mentioned its only a charger when using the ac adapter that came with your ipad..
    1) It has a nice durable feel to it, color is gloss white (the gloss flare I did w/ photoshop) and goes well with the ipad..
    [​IMG]
    2) The bottom has some kinda of rubber material, is good so it wont move around, good thinking by the maker..
    [​IMG]
    3) The ipad fits great in this stand, very sturdy, doesnt flake around..
    [​IMG]
    [​IMG]
    [​IMG]
    And finally there is port for audio out (line out) as well as port for the ipad av cable (out) so you can output to TV.. These ports are important to me especially the audio out as when I listen to music with speakers or headphones, I can plug in and out and not having to worry about port breaking on ipad, if the port breaks on stand I can replace with another, port break on ipad- thats an issue, especially after warranty has expired. (this has happen to me on many radio/mp3 devices, and the device would become unusable..)
    [​IMG]
    Quality and craftsmanship is great, for 5 dollars Im impressed..
    I give this stand a 8.4 out of 10..
    I would like it more if it had adjustable angles, but hey, did I mentioned I only paid 5 bucks (including shipping)
    Is available all over Ebay, just put in "ipad stand" in search, you will find it!!
    #1 Ultrimate, Jul 30, 2010
  2. Drag Bunt
    Drag Bunt
    Jul 13, 2010
    151
    Looks like a direct knock-off of the official Apple iPad dock
    but substantially cheaper. Now, if would only work with a skin attached
    I bought one anyway..
  3. frunkskunk
    frunkskunk
    Jul 30, 2010
    Thanks for the review, was looking for this.
