3g USA iPad troubleshooting Edge network in India
Discussion in 'iPad Help' started by ipadindia, Mar 15, 2011.
  1. ipadindia
    ipadindia
    Mar 15, 2011
    I'm posting this from India, on my own 3g iPad bought in USA, so I do know a few things about using an iPad on 3g outside of USA. A friend brought over a similar iPad 1 bought in USA (with ATT SIM inside) and wanted to get network access on the local ISP here where I live, near Pune India.
    This is a bit weird. I put my working local SIM into my friend's USA iPad, and couldn't log onto the local (Idea Cellular) network using the exact same APN, Username and password settings I use. The only difference I can notice between our iPads is that she had never activated the 3g in USA using ATT. I did use ATT for a few weeks before coming to India, and I haven't had any trouble with 3g on other networks. Is there something else required to get 3g active?
    I noticed in the settings that her system doesn't include a "Carrier" tab as mine does. It has "Cellular data" and "Data roaming" turned on, but though the system recognizes that there is a SIM inside, it doesn't seem to even try to find the network here. In the "General" -- "About" section it says "Network not available" Do you have to go through the ATT activation process before leaving USA to get 3g working? Seems a bit strange if so since others on this forum seem to have been able to take a USA iPad out of USA and successfully log onto foreign 3g networks without ever activating an ATT account in USA first.
    Any suggestions most appreciated!
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,235
    122
    You have undertaken a very thorough investigation and have come to the correct conclusion!! Yes, you need to sign up with AT&T first of all.
    If you read through the thread below, you'll see (as usual) I'm making some entirely spurious suggestions (no change there!) and then, the poster, finding out by visiting the store that they did need to sign up....
    http://www.ipadforums.net/ipad-help/17319-no-service-coverage-area-help.html
    Not sure what can be done from India.
  3. ipadindia
    ipadindia
    Mar 15, 2011
    Thanks for the info and suggestions. She lives in Moscow some of the time and could probably get some help at the Apple store there. I think that's what I'll suggest, since there aren't true Apple stores in India. There are stores that sell Apple products here--iPad 1 arrived here just in time for iPad 2 be released in USA ;-) But they don't seem too savvy at these places, whereas the true Apple stores seem to find solutions.
  4. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,235
    122
    There’s some subtle low-level stuff in the iPad! In the UK iPads are sold entirely unlocked most (all?) places. When I bought mine (at an Apple store) there was a microSIM slot, but no SIM. You got those from whatever service provider you chose! No need to ‘sign up’ - simply insert the SIM and away you go! APN etc all set up automatically from the SIM.
    Clever stuff!
  5. krk
    krk
    Mar 3, 2011
    5
    This seems weird, my assumption is the IPads are not subsidised by the service provider like AT&T and can work with any SIM.
    If this is true that AT&T has not subsidised the device what right do they or anybody has to cripple the device.
    They only have the their own SIM card which they can assign to a specific service or feature. The IDEA SIM should have worked identical as in your IPad.
    In India I purchased the 3G IPhone which was officially released in India and was carrier locked to Airtel for 12 months. On expiry of 12 months neither Airtel nor Apple India would own up the unlocking of the IPhone.
    It was many months of back and forth mails and escalations later did my 3G IPhone get officially unlocked.
    It is another matter on what basis the device was carrier locked in the first place, without any subsidy being offered. I payed bloody Rs 36100/- (USD 7xx) to be carrier locked ?????
    Further over time I could see that the 12 months lockin period with Airtel was changed to undefined duration on Apple website.
    Probably it is a matter of taking AT&T and Apple to task as I did with Airtel & Apple India.
    The Apple premium resellers in India are absolute duds, do not ever imagine one bit of Apple genius / Bar experience as in US. The best bet is to call Apple India helpline directly.
  6. ipadindia
    ipadindia
    Mar 15, 2011
    3g USA iPad issues
    That's helpful to know about the iPhone in India. I've sometimes thought about getting one, but it would have to be *truly* unlocked in order to be of use to me.
    I also had it in mind to ask Apple in USA about this weird requirement to "unlock" an "unlocked" iPad in order to use 3g out of country issue when I get the chance. It seems to be entirely a software issue. Before I bought mine the sales rep at the Apple store in USA told me the software was "locked to ATT." After using mine outside of USA I assumed he didn't know what he was talking about, but now I realize he must have known something valid even if he didn't know all the details or didn't want to elaborate.
    Another little-known detail I learned from that same sales guy about iPads bought in USA is that Applecare bought for them authorizes repairs anywhere in the world--an important consideration for me. Applecare for an iPad bought out of USA is only valid in the country where the iPad was purchased--not always so good for frequent travelers.
  7. ipad2india
    ipad2india
    Apr 8, 2011
    Hi...
    can you tell me if the issue is similar with the iPad 2...
    This is my situation. I bought an iPad 2 At&T from the US.
    I planned to bring it to India and switch it on...I have a Tata Docomo and BSNL micro-sim ready for the iPad2.
    Will this work directly or should I activate the AT&T service in the US and then bring it down to India for easy access? Please let me know...I have 4 days before i leave from the US...
  8. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,235
    122
    We are getting contradictory information on this - with some users reporting that they had to activate the iPad in the US before returning home (most reports) but with one user reporting he bought an AT&T iPad in the US and had no trouble when he got home to Russia.
    So I guess, if I were you, I'd play safe - buy a cheap AT&T pre-paid SIM and activate it in the US.
  9. ipad2india
    ipad2india
    Apr 8, 2011
    Thank you Tim :)
    Just one more question...when i spoke to the Apple executive who sold me the iPad2, he said that the device was locked to At&T. When i checked, no iPad2 was ever sold dependent on a carrier. So can i just treat the Apple executives word as 'misinformed'...?
    By default, it is unlocked right?
  10. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,235
    122
    I think he might have been referring to the issue of having to initialise it first in the US. For sure, other than that possibility, it's not locked to AT&T.
    PS sorry I was so slow in answering this question
can i use a 3g ipad in india purchased in usa
can i use ipad 3g in india
can i use my ipad with 3g bought in usa in india
can ipad 3g purchased in us be used in india
how to use american ipaf in india
ipad bought in usa work in india cellular
ipad in india same as us
unlock ipad2 mini at&t sim for india
using an ipad in india
using ipad in india
