wifi hard drive
This is a discussion on wifi hard drive within the Portable WIFI Drives forums, part of the iPAD Connect category; Originally Posted by Mbspears I have 3 options for you: Airstash which let's you use any SD card and broadcasts using an ad-hoc wi-fi connection. ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: wifi hard drive
  1. #11
    49720
    411 times
    SC
    6,330
    Quote Originally Posted by Mbspears
    I have 3 options for you: Airstash which let's you use any SD card and broadcasts using an ad-hoc wi-fi connection. I believe it is now under the Maxell brand -- it was independent when i got it. Kingston Wi-Drive works the same way, but has fixed memory (no SD or USB) -- comes in 16 or 32 Gb. I just to the 32 Gb for < $90. The third is the CloudFTP sold by Hypershop. This broadcasts an ad-hoc wi-Fi connection or it can join an existing wireless network. This device has a powered USB slot so you can you a USB stick, portable hard drive, or memory card reader. I have all 3 - Wi-Drive is nice as it is the size of an iPhone, but is not expandable. Airstash is ok, but seems too slow for video streaming sometimes. CloudFTP rocks! This started as a Kickstarter project by a college engineering student. Expandable with any USB Drive. I will now travel with that and a 500Gb hard drive for lots of videos! Both CloudFTP and WiDrive have no trouble streaming 1080p video!
    I don't see the advantage of the cloudftp device over the air stash and a large sdxc card or several sdhc cards. The air stash is small by comparison so it travels easy compared to both the cloud device and some USB hard drive. And the speed is dependent on the speed of the storage. I have streamed 1080p on the air stash too with no problem. Actually, that's not saying a whole lot because the bit rate of the encode is more important than the resolution. That why so 50GB blu ray is not the same as a 2gb rip of the same movie.
    Right now, I'm streaming to 1080p rips from the Air Stash at the same time (one to iPad the other to iPhone 4S). I'm also downloading a third movie to my laptop. All of it is working great. I don't see any reason to think that the Air Stash is slow...unless you put a slow SDHC card inside.
    BTW, I'm talking about the Air Stash A02.
    mini iPad w/ RD - 128 LTE - Space Grey | iPad mini - 64 GB - LTE - Black | iPad (3nd Gen) - 64GB - LTE - Black | iPhone 4S - 64GB - White | Nexus 10 | Nexus 7 2013 | Kindle Fire
    * * * Forum Rules * * *
  3. #12
    181043
    Mar 2012
    Toronto, Canada
    74
    I am using FileBrowser to connect to my time capsule wireless hard drive. While it is not really portable, it works great around the house and I was able to configure it for remote access as well.
  4. #13
    66612
    7 times
    Jun 2011
    Montreal Canada
    112
    I also use FileBrowser . It is great. I also have a folder on my NAS drive that I sync with my IPad/Goodreader for the files I want to carry around.
    Sent from my iPad2 3G 32 gig (not JB'ed) / using iPF
  5. #14
    1583
    52 times
    Mar 2010
    Oklahoma
    2,522
    While I like the concept of the cloudftp, I have to say the price is a little much. I think I would prefer the air stash ao2 , but then again, I rarely have much need for high storage capacity. Just one or two 32gb SDHC cards would suffice.
  6. #15
    190692
    Apr 2012
    memphis
    41
    Quote Originally Posted by Seadog View Post
    Airstash is great for making copies of SD camera cards in the field! I plan on using my on Safari in Tanzania with a USB charger that uses AA batteries!
  7. #16
    49720
    411 times
    SC
    6,330
    I just bought my Air Stash A02 and want to know if I should keep it or get something else (maybe the Cloudftp). So far, I see no reason to return it...other than the fact that it doesn't seem to work well with my Android devices. But it works great on iOS devices. Its speed, in terms of streaming, seems to be determined by the SDHC card used. I have a faster one, as I tested it with CyrstalDiskMark. It is a good bit faster and reads than the one it came with (I bought the 8GB model for $127). It's not cheap. I'm a digiial hoarder so I seem to have no end to my storage needs (desires), but I'm going to resist buying one of those 128GB SDXC cards.
    Another advantage of owning this...if go to a conference and only take an iPad and want to exchange files with people who have laptops. This give you an easy way to do that because you have two ways to transfer files: usb or wireless. The A02 is much smaller than the A01, too.
  8. #17
    195769
    Apr 2012
    Sheffielf
    7
    You can only buy them from the hyper drive website
  9. #18
    k_m
    k_m is offline
    263300
    Dec 2012
    atlanta
    Note: the Ipad does not have enough juice to run a non-powered external hard drive. For this to work, the USB portable hard drive would have to be self-powered
  1. Goflex satellite wifi hard drive
    By tobins in forum iPad 2 Forum
    Last Post: 06-26-2012, 07:17 PM
  2. Seagate GoFlex wifi Satellite external hard drive
    By scubadiver12165 in forum Portable WIFI Drives
    Last Post: 05-17-2012, 08:06 AM
  3. Can i use a portable hard-drive in anyway?
    By jam501 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 12-18-2011, 03:25 AM
  4. 1 terra hard drive via usb
    By nikgns in forum iPad Help
    Last Post: 07-05-2011, 07:24 AM
  5. Is there a way to use Ipad as hard drive or Flash drive?
    By Grizz1415 in forum iPad General Discussions
    Last Post: 11-28-2010, 09:39 AM
airstash vs cloudftp
airstash vs wi drive
cloudftp vs airstash
portable wifi drives
wifi drive
wifi drive ipad
wifi hard drive for ipad
wifi hard drive ipad
