Results 1 to 3 of 3
    127264
    Nov 2011
    Wifi drive / media player
    Have a seagate wifi drive and I have all kinds of media loaded on there and I'm trying to get the iPad to stream the different media types but it doesn't seem to work
    Seagate suggested the purchase of the Oplayer app, which I did however it doesn't seem to play any of the non-apple supported media types
    Wondering if anyone has a similar experience and has overcome this hurdle
    A
    23938
    Dec 2010
    Maryland
    12
    There are a couple of things to consider here. First of all don't assume the problem is with the Seagate.
    In order to play streaming video or video of any kind for that matter you will need two components 1. A media Server (your Seagate) and 2. A UnPn or DLNA aware player. Both must understand the format of the data you've stored.
    The iPad typically does not understand many formats If your media is in .avi or wmw format then it will not play.
    Your options are to to attack the problem on the server or with a player that has wider video support.
    Search the app store for "DLNA" media players and try them to see if that helps otherwise you're going to either have to translate your media to .mp4 format before the iPad will recognize it.
    iPF Super Guru
    40746
    94 times
    NW Left Coast
    3,504
    Quote Originally Posted by adamo74 View Post
    A
    I'm assuming that you have the Seagate GoFlex external hard drive:
    GoFlex Satellite Wireless | Seagate
    That is the only Wi-Fi hard drive that works with the iPad.
    If that's the hard drive you have, you need to use their app to view videos.
    App Store - GoFlex Media (Seagate Technology)
    There are a few other apps that are optimized for it as well including the Oplayer.
    These are the media types that are supported on the iPad:
    H.264 video up to 1080p, 30 frames per second, High Profile level 4.1 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; MPEG-4 video up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps per channel, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file format.
    As Wpeace mentioned, you won't be able to play anything else without actually converting the file(s) to play on the iPad.
    Hope that helps a little!
  1. NAS/Media Player/App combination to stream media, controlled from iPad
    By thelongroad in forum iPad General Discussions
    Last Post: 01-06-2012, 08:35 PM
  2. media player
    By valetta11 in forum iPad Help
    Last Post: 11-05-2011, 10:10 AM
  3. Best media player for iPad 2
    By FruitJuice in forum iPad 2 Forum
    Last Post: 07-23-2011, 06:33 PM
  4. Since the demise of VLC media player what's the best player for video
    By lanimae in forum iPad General Discussions
    Last Post: 03-25-2011, 10:45 PM
  5. AirStash wireless flash drive w/ media streaming & WebDAV for iPad
    By xune in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 01-07-2011, 01:39 AM
best media player for wifi hard drive ipad
ipad wifi media player
ipad wifi player
media player application
oplayer to ipad wifi
play m4v on ipad 2 from external hard drive
player ipad wifi
seagate wifi media player
watch movies on ipad from hard drive
watching movies on ipad wifi drive
wifi app hdd for ipad
wifi play ipad
