Seagate GoFlex wifi Satellite external hard drive
This is a discussion on Seagate GoFlex wifi Satellite external hard drive within the Portable WIFI Drives forums, part of the iPAD Connect category; I've been contemplating on whether to purchase the Seagate Goflex wifi Satellite external hard drive. The 32 GB on my ipad2 is simply not enough ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Like Tree2Likes
Thread: Seagate GoFlex wifi Satellite external hard drive
    50995
    May 2011
    VA
    26
    I've been contemplating on whether to purchase the Seagate Goflex wifi Satellite external hard drive. The 32 GB on my ipad2 is simply not enough to store all the movies, home videos taken with the iPad, games and such. I read online reviews from places such as Amazon and Newegg and there seems to be more negative comments about it than there are positives. I was wondering if anyone here has experience using it. If so, what is your honest opinion of it. Worth buying, get something else or hold off for something better to come along?
    92772
    4 times
    Aug 2011
    Louisiana
    11
    I had one for a couple of weeks and ended up returning it. It worked OK for movies but wasnt worth the nearly $200 in my opinion. A lot of the negative reviews I read were true.
    Cons:
    1. It was slow populating thumbnails EVERY time you turn it on
    2. The file system is as bad as everyone says it is
    3. You cant be hooked to internet and goflex at same time
    4. And finally the most unacceptable con for me was that you cant play movies on the HDMI out adapter like you would with Netflix on a TV or projector. The video only plays in the smaller mirror image version and looks like crap.
    pros:
    1. The video streamed smoothly and looked good on the ipad
    2. It is very quiet and small for a wireless hard drive
    I ended up getting the camera connection kit and just put all my movies on an SD card and transfer them to my ipad now. This way I have pretty much unlimited storage in a much smaller package.
    1523 times
    Walla Walla, WA
    15,431
    Check out the AirStash. I don't' have it, but I believe the reviews are better. It may not have the capacity of a HDD solution, but SD cards would be more flexible.
    11919
    10 times
    Aug 2010
    Virginia, USA
    732
    I have both the Air Stash and the SeaGate Go flex
    Both work just fine for me. The Seagate is pricey but it is also 500 gig compared to the much loser cost Air Stash that is limited to the (extra cost) SDHC card's capacity. Start with the Air Stash with a 32 gig SDHC card and see if that solves your problem. It is much smaller and less expensive than the SeaGate
    If my Irish Wolfhound doesn't like you neither will I.
    2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
    104773
    Sep 2011
    I bought the Seagate for my sister and quite the time setting it up.
    1st off most of the files I wanted her to be able to use were avi's. I had to download (buy) Azul player in order to play the avi's. .movs and .mp4 stream just fine from the Seagate. Azul downloads the file off the Seagate on to your ipad then plays them. It works just not as nicely as mp4s. I guess after she fills up her ipad drive she will have to delete the files she doesn't want.
    104773
    Sep 2011
    FYI, the Buzz Player HD is (so far) the best player I have found for playing (streaming) avi's from the Seagate Satellite.
    199918
    May 2012
    Help
    Quote Originally Posted by AlacrityF View Post
    Can anyone help me please, I have a bunch of avi files on my goflex drive however only files less than roughly 400mb will play. I try to load a 2 hour 700mb avi file and try playing with buzz player, Oplayer, VLC player and nothing happens at all, it just stays on the segate page and nothing loads, what is wrong !!!
    2888
    53 times
    Apr 2010
    Fort Wayne, IN
    1,230
    Quote Originally Posted by Chronicals
    Hello Chronicals, welcome to the forum. In a short while, you will soon be greeted by a super moderator. They will give you excellent "welcome to the forums" links. Be sure to read those links as they will give you all the information you will need to participate on this forum.
    Chronicals, you pulled up a very old thread about the Seagate GoFlex drive. There are some newer threads but they do not address your specific question--I too am interested in this topic as I just bought one, it will be delivered Monday, May 7th. I'm doing a lot of searching on this forum and elsewhere to help myself get ready to play with a new piece of technology! I'm replying to your post hoping others with direct experience can help us answer your questions.
    Once again, welcome to the forum!
    48665
    945 times
    Brisbane, Australia
    23,476
    Hi and welcome to the Forum!
    I too am interested in this subject.
    iOS5 Tips and Tricks
    skipsey likes this.
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
    56481
    5 times
    May 2011
    184
    I have a goflex and will take a shot at addressing your questions.
    First, connect the ipad to the goflex wifi.
    Then, open buzz player hd.
    At the bottom of the screen, tap the smb/ftp icon.
    The goflex should show up as a upnp guest connection.
    Tap that to connect buzz player to the goflex.
    If you have the goflex password protected, you will be prompted to enter the password the first time you connect, buzz player will remember the password the next time you connect.
    You should be able to see several folders. Just navigate to your movie and select it.
    The goflex app will only play movies with the ipad compatible file extensions.
  1. Seagate GoFlex Satellite?
    By RAC in forum iPad General Discussions
    Last Post: 11-07-2011, 02:26 AM
  2. Replies: 2
    Last Post: 10-30-2011, 11:26 AM
  3. External Hard drive
    By pearliegirl5 in forum iPad General Discussions
    Last Post: 08-02-2011, 02:32 AM
  4. External Hard Drive
    By BadBoi2011 in forum iPad Help
    Last Post: 07-22-2011, 01:13 AM
  5. External hard drive?
    By GeorgieB in forum iPad 2 Forum
    Last Post: 04-20-2011, 04:22 PM
buzz player goflex satellite
connect goflex to azul
do i have to load itune movie before transfer to goflex satellite
goflex satellite xbmc
goflex satellite xbmc ipad
how to play avi file from goflex satelit on the ipad
how to play your content on seagate wifi with vlc
ipad cannot play video on seagate goflex satellite
