Wireless Portable Harddrive???
This is a discussion on Wireless Portable Harddrive??? within the Portable WIFI Drives forums, part of the iPAD Connect category; I am one of the people trying to solve the issue of manipulating space on iPads. I wonder if there are truly commendable Portable HD's, ...
Results 1 to 4 of 4
    iPad Addict
    39793
    7 times
    Oxford, MS
    1,043
    I am one of the people trying to solve the issue of manipulating space on iPads. I wonder if there are truly commendable Portable HD's, which you can access via wi-fi and if iPad would recognize it as a storage bin. Would it need an app to work through. If it would be "press-n-play." I'm not much of a techno, under the bevel person, but I have an imagination. I just may not have the jargon.
    As many of you know, Seagate bought the prized externalists Maxtor and has since integrated Maxtor's functionality with Seagate's appeal. They have Flex Drive which work over "Net Media" or something, but they seem to be working harder on making things smaller and fit the HDTV and HD entertainment lifestyle.
    Do you think they can make a drive readable by other portable devices?
    Am I dreaming?
    Is it a good idea or flawed? (I know it's marketable. Much better than 20 SD cards and low-powered CCKs)
    What are your thoughts? Have you come across any other companies?
    6565
    Jun 2010
    USA
    54
    21596
    Nov 2010
    Los Angeles
    33
    It depends on how much stuff you want to carry around with you.
    There used to be 2.5" wifi nas drives with internal batteries, but the cases are not easy to come by. It was long enough ago they used PATA drives. If you could find one, you could use an app to access a share on the drive.
    There are oddball wifi nas adapters, like the CDS530AM, that would let you plug in your regular USB drive, but you'd need power and they aren't exactly a stock item at best buy.
    Or you might be able to dig up a WL-HDD, again though you need power. Not really portable, just transportable.
    If money is no object, get an OQO v2 and a USB hard drive.
    Short of that there is the airstash, but its only SD. If you don't mind keeping everything on 32gig SD cards it might be the way to go.
    Moderator
    50404
    448 times
    May 2011
    Bromley, Kent
    7,533
    Charging a portable drive while traveling
    One consideration is battery life. Is the battery life of a portable drive the same as that of an iPad?
    Does the portable drive come with a jack lead which can be plugged into the accessory power point in a motor vehicle?
    Just commenting
    Brought to you from my super iPad3 - used as from 03/10/12
    Richard M Brown
    Bromley, Kent, UK
    Please read the forum rules: http://www.ipadforums.net/forum-rule...ease-read.html
  1. Muzetto Portable
    By jcbeam19 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-12-2011, 01:42 PM
  2. Apple's Wireless Keyboard vs. Matias Wireless Folding Keyboard
    By WannaBeMac in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-23-2011, 08:36 PM
  3. Speakers-portable
    By CMFox in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 12-20-2010, 07:41 AM
  4. IPad as a harddrive
    By Shoma5er in forum iPad Help
    Last Post: 11-15-2010, 02:09 PM
  5. SSD - harddrive?
    By OmarKN in forum iPad General Discussions
    Last Post: 05-10-2010, 09:48 AM
bluetooth external hard drive for ipad
bluetooth hard drive for ipad
bluetooth hard drive ipad
bluetooth hdd
bluetooth portable hard drive
ipad bluetooth hard drive
portable bluetooth hard drive
portable hard drive with bluetooth
Tags for this Thread
