Mac help
This is a discussion on Mac help within the Off-Topic forums, part of the Apple iPad Discussions category; so im selling my MacBook Pro (again) and i have let someone borrow it for a couple weeks, so i wanted to know what i ...
Results 1 to 3 of 3
Thread: Mac help
    iPad Enthusiast!
    2397
    Apr 2010
    60
    Mac help
    so im selling my MacBook Pro (again) and i have let someone borrow it for a couple weeks, so i wanted to know what i can do to clear the hard drive easily? im looking for an equivalent to an iPad restore if possible. anyone know of anything?
    iPad Junkie!
    3751
    May 2010
    Beaumont TX
    195
    I haven't done this but I think you can just use Disk Utilities in the Utilities folder in the applications folder. And reformat your Hard Drive, it can rewrite everything to zero or you can do some higher security rewrites of the drive. And then you would need the install disks to re install OSX. Hope this helps, I don't know if this is the best way but just an option. Should be info about reinstalling the OS on the Apple website.
    I found the following page and it describes how to use the OS X install disc to reset to factory setting. Good Luck
    http://manuals.info.apple.com/en_US/...structions.pdf
    2105
    Apr 2010
    Cologne, Germany
    522
    In Diskutility you can do a secure erase. Takes ages, but deletes all data for sure.
    Most likely written on my iPad
