Results 1 to 5 of 5
    167823
    18 times
    Feb 2012
    Brooklyn, New York
    365
    HOW TO- DFU your device with a broken Power and/or Sleep Button
    In this tutorial, we'll be learning how to create a DFU IPSW. A DFU IPSW is an IPSW that can be used with iTunes to put your device into DFU mode. This IPSW is basically a repackaging of the stock IPSW in a way that your device will go through the restore process, but will result in your device going into DFU mode, which is ideal for users with a broken Power/Sleep and/or Home button(s). Note that this will work for all devices and does not restore your device. Again, it simply goes through the restore process, but puts your device into DFU mode.
    Use:
    When jailbreaking or restoring your device for any reason, you'd either be prompted to or would be better to DFU your device. Since your device's power and/or home button is no longer working, DFU-ing your device can be problematic. By creating a DFU IPSW, you can simply open up iTunes, shift/command + click Restore, and point it to the ENTER_DFU IPSW you've created, let iTunes "restore", and in the end, your device will be in DFU mode. Note that the IPSW selected MUST be the latest iOS because it has to be validated by Apple's servers as does all IPSW in use with iTunes.
    Essentially, this will work for any and all devices as long as it's the latest iOS IPSW selected.
    What you will need:
    • RedSn0w: Windows Download || Mac OSX Download
    • The LATEST iPad iOS IPSW for your device: Downloadable here
    • A copy of iTunes that supports the latest version of your iOS (latest iTunes would be best)
    • USB Cable (of course)
    Step 1: Run RedSn0w as an administrator (if applicable)
    Step 2: Click on Extras
    Step 3: Click on Even More
    Step 4: Click on DFU IPSW
    Step 5: Find and select the LATEST iOS IPSW that you downloaded. It MUST be the latest iOS IPSW
    Step 6: Allow RedSn0w to stitch a new IPSW
    Results:
    Once the IPSW creation has finished, you will see a new IPSW in the same directory as the IPSW that you selected. i.e. If the IPSW that I selected is on my desktop, a new one will appear on my desktop. The name will be the same name as the IPSW that you selected but with the header ENTER_DFU_.....
    -End-
    iPhone 4S White 16GB iOS 6.1.2 || iPad 2 (Black) 16GB WiFi iOS 6.1.2 || iPhone 5 (Slate)/iPhone 4S (Black) 64GB Latest Beta/Full iOS
    iPhone Forums Moderator
    292277
    May 2013
    New York
    Nice information, Thank!..
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    Thanks for noticing we already had this covered Jon
    HOW-TO - Activate DFU Mode when you have a broken button!
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    167823
    18 times
    Feb 2012
    Brooklyn, New York
    365
    Oh wow fail.... Never mind lock/delete please
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    Quote Originally Posted by willerz2 View Post
    No need, its all good.
  1. Replies: 0
    Last Post: 01-04-2013, 10:53 AM
  2. Replies: 0
    Last Post: 07-14-2012, 06:43 AM
  3. Power Button & Home Button Sometimes Acting Weird
    By shakra00 in forum iPad General Discussions
    Last Post: 04-11-2012, 02:07 AM
device not registered portal broken power button dfu
