WiFi Booster - Paid Tweak
This is a discussion on WiFi Booster - Paid Tweak within the Jailbreak Applications & Tweaks forums, part of the iPad Hacking category; Originally Posted by f4780y I purchased an excellent new tweak from Cydia this week. WiFi Booster from Malcolm Hall ($1.99) removes the signal strength limit ...
Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 54 of 54
  1. #51
    159794
    2 times
    Feb 2012
    Des Moines, IA
    80
    Quote Originally Posted by f4780y
    I purchased an excellent new tweak from Cydia this week. WiFi Booster from Malcolm Hall ($1.99) removes the signal strength limit allowing you to see and connect to weak WiFi networks in your area from the iPad WiFi Settings. It also enhances the network view to include the MAC address of the access point [blurred out in my image ] and the signal strength.
    As you can see in the image below, I can now identify two weak networks which would normally be hidden without this tweak because they are outside of the iPad's original signal strength limit. Very handy since one happens to be an unsecured wireless router with an 8MB internet connection behind it
    If you like your WiFi, look into this! It really works and has the f4780y seal of approval
    What do the negative number in between the router name and the signal strength signify?
    Sent from my jailbroken iPad2 using iPF
  2. #52
    Banned
    12904
    32 times
    Aug 2010
    Raleigh, NC USA
    3,664
    Quote Originally Posted by HowBoutThemPack
    Wifi signal is commonly measured in dBm. It is measuring the stregnth in decebels. Its not really negative, (because that would be impossible to have negative wifi signal), just the lower the number, the better the signal. I think they are negative because it measures signal loss. (I think)
  3. #53
    175164
    Mar 2012
    Omaha nebraska
    157
    Dose it drain more battery cause it has to work more to try to get the internet
    loving my iPad 2 jailbroken
    sent using iPF app
  4. #54
    Banned
    12904
    32 times
    Aug 2010
    Raleigh, NC USA
    3,664
    Quote Originally Posted by Amp1216
    If the signal is really low.
Sponsors
  1. Dock - Paid Tweak
    By Mickey330 in forum Jailbreak Applications & Tweaks
    Last Post: 01-20-2012, 08:45 PM
  2. Wifi booster plug in
    By saphire in forum iPad Accessories
    Last Post: 12-15-2011, 11:02 PM
  3. Wifi signal booster help
    By Woodwitch in forum iPad Accessories
    Last Post: 12-15-2011, 10:43 PM
  4. What is your favorite cydia app / tweak?
    By graywolf in forum iPad Hacking
    Last Post: 08-25-2011, 12:45 AM
  5. ChangeCarrier - New Cydia Tweak
    By f4780y in forum iPad Hacking
    Last Post: 01-27-2011, 03:18 PM
apple wifi booster
cydia wifi booster
ipad 2 wifi booster
ipad wifi boost
ipad wifi booster
ipad wifi booster app
ipad wifi enhancer
ipad wifi signal booster
ipod wifi booster
wi fi booster for ipad
wifi booster
wifi booster app for ipad
wifi booster cydia
wifi booster for ipad
wifi booster for ipad 2
wifi booster ipad
wifi booster ipad 2
wifi booster ipad app
wifi booster tweak
wifi enhancer
