Numbers formula help
This is a discussion on Numbers formula help within the iWork Forum forums, part of the iPad App Store category; That's an interesting solutions. Thanks for sharing it. Here is a quick tip, if you have not discovered it for yourself: To quickly enter the ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    iPF Elite
    176 times
    Dayton, WA
    9,230
    To quickly enter the current date in to a cell, try this. Instead of entering each item (month, day, year) in order immediately select day. A Today button will appear on the keypad. Tap it an the other two values will be entered as well.
    Makes date entry (almost) bearable.
  2. #12
    156835
    Jan 2012
    8
    Wow never knew about that trick, thank you for sharing that twerppoet.
  3. #13
    iPF Elite
    176 times
    Dayton, WA
    9,230
    No problem. I stumbled onto it when I had to enter a large number of dates to test a spreadsheet.
    You can do the same thing with the time using NOW after selecting the hour. Of course that is less useful, but there.
  4. #14
    173138
    Mar 2012
    Tampa
    Can someone please tell me how to navigate to SUMIF ??
  5. #15
    iPF Elite
    176 times
    Dayton, WA
    9,230
    You tap the Function key when in formula editor mode. On the menu that pops up choose the Categories tab, then either All or Numeric category. Swipe to scroll down until you see the SUMIF function. Tap it to select, or tap the blue arrow to the right of it for a description and examples.
    Once you've selected and used it should show up in the Recent tab.
  6. #16
    173138
    Mar 2012
    Tampa
    Thank you sooo much : ) Still learning my way around....had a blonde moment!
  7. #17
    iPF Elite
    176 times
    Dayton, WA
    9,230
    Not a problem.
Sponsors
  1. iPad Numbers formula help
    By Zera in forum iWork Forum
    Last Post: 09-02-2011, 08:49 PM
  2. Help with Numbers formula
    By Jmfocus in forum iWork Forum
    Last Post: 08-30-2011, 09:06 PM
  3. Numbers help with formula running down a page
    By BoredFatMan in forum iWork Forum
    Last Post: 05-11-2011, 01:19 PM
  4. Numbers Formula Instructions
    By Hal05154 in forum iWork Forum
    Last Post: 01-23-2011, 03:37 PM
  5. Formula One Car Crash Video
    By Gabi in forum Off-Topic
    Last Post: 09-21-2010, 02:04 AM
apple numbers help if function
apple numbers using the if statement
copy number out of iwork not equation
date formulas ipad numbers
help apple numbers formula
help with numbers formula
how to add current date in numbers for ipad
if statement in apple numbers
ifsums function with more than one criteria
ipad forums numbers
ipad nmbers if function
iwork numbers circular references
iwork numbers today date formula
iwork pages numbers sumif formula
mac numbers if statement
numbers formula help
numbers formulas help
sumif multiple condition in iwork
sumifs iworks ipad
where is sumif in numbers for ipad
